Whew, finally done! (I think)
Finally finished my install on my 2002 TL-S w/Nav. Not going for super-loudness or competitions/showing off - just wanted good music - and I wanted to keep the stock headunit (for the factory look, in-dash changer and steering wheel audio controls.) Lost my web hosting space, so I'll have to put these pics up one at a time (sorry moderators, please don't kill me!!!
AllanC45
Here's the Sony 7547-ES amp (last year's model, not that cheezed out ES one they have this year). Haven't installed the wiring cover yet because I'm still tweaking the levels and such:
)AllanC45
I was very fortunate enough to get these electrical diagrams from my dealership, Don Mealey Acura near Orlando, FL. If you choose to make use of this info, *PLEASE* be careful, you could easily damage your car if you don't know what you're doing. Not that I'm an expert, I just went through it *very* slowly, since I didn't want to harm my 4 month-old car :p
Thanks to those who've helped me along the way, especially TLDaddy, and the rest of the forum community! Happy trails!
Stock Bose
New amp and speakers
AllanC
Stock Bose
AllanC
YOU THE MAN
thank you so much, i just got my stereo system installed, subs amps but not my components....and i must say... with the EQ still kicking in and 75 going into each stock speakers(front) it sounds really good for stock......i'm really impressed.... but its already a bit too harsh and bright..... i know it'll sound nasty with my MB quart PSCs.... so i'm going to bypass the EQ for sure.... the guys who installed my system also did a bad wireing job, so i'm ganna re-do my wiring too..... they ran my 16 gauge speakerwire alon with my 4 gauge power cable and tapped it into my stock speaker wires...... if you want a job done right you ghatta do it your self.....they also power and gound my audio control HPX with the stock headunit....and grounding for each of the amps are more then 1.5 foot long....
that looks good, I take it you added the focals up front and the kappas in the rear and left the stock sub in. I have 1 question about that setup how does the sub fit in with the aftermarket stuff you added can you still hear it or is it drowned out by the new stuff
actually, I initially replaced the stock speakers w/ 4 Infinity Kappas 52.1's. Now I've removed those and replaced them with the 4 focal woofers and 2 tweeters.
I haven't done anything to the stock sub and sub amp. And yes, they still contribute greatly!
AllanC
AllanC
That would be door #2, Monty
- or in other words, yes, that's exactly what I did, connecting the eq sends right back into the eq returns, as my poor scribbling on the diagram show.
Word of warning, I'm still attempting to hunt down the minor alternator hum I'm now getting since the bypass of the EQ. I'm fairly certain that it is because I have not grounded the the open inputs going into the EQ. I'll confirm that as the cause as soon as I get a minute to tear open the center console again
AllanC
AllanC
Originally posted by allanc45
The focals are 5 1/4". Perfect size if you ask me, not so small that they can't do great midbass, not so big that you have to enlarge the door cutout (I am NOT chopping up my door panels
AllanC
)AllanC
) But remember, either speaker size will require you to fabricate some standoff rings, which effectively reduce the install depth.-djsteve
[/B]
[/B]
If grounding the open eq inputs doesn't fix it, I'd suspect a ground loop between your outboard amp and the factory HU. Good luck!
-djsteve
Quite welcome - I'm thankful that the people on this board gave me the info and confidence to be able to try the install myself (ok, I DID do my own install on an 83' Ford conversion van, but, we'll just pretend that doesn't count
, cuz is doesn't)
I'm sure once I close those open inputs, the problem will go away - just being plain lazy
AllanC
, cuz is doesn't)I'm sure once I close those open inputs, the problem will go away - just being plain lazy
AllanC
any chance on getting the wiring diagram for the stearing wheal controls? I am thinking about putting together a module for alpine head units that i can feed the stearing wheel controls into and the module translate that to an IR signal to control the alpine.
There is a company that makes a controller that will allow the stock steering wheel radio controls to work with any head that has IR control. I wouldnt bother messing with making your own.
HERE IS THE LINK
HERE IS THE LINK
