What's a Good small 4/ch amp?
Old Jul 9, 2002 | 08:09 AM
JasonT's Avatar
I need a 4 channel amp. Needs to be about 50W/ch. I need a small amp though. The smaller the better. I need to mount it inside my rear panel in my explorer. Any ideas? Or recomendations?
Old Jul 11, 2002 | 02:21 PM
PnoySport's Avatar
ALPINE V-POWER
it's a decent 4 channel amp. it's small and u can probably fit that in where u want. it's just there entry level 4 channel but alot better than what's in the car now. remember i said V-Power not V-12 those definetly won't fit.
Old Jul 11, 2002 | 09:27 PM
AcurajL's Avatar
I hand out swivel heads
amp size
The Alpine is 250 mm long by 170 mm wide and 2.1 mm deep, rated 50X4 rms when bridged 4 ohms. That is there 4/3/2 model....
The JL 300/4 is 75 X 4 RMS anywhere between 1.5 ohms to 4 ohms, it is 13.4 inch long and 9.25 wide and 2.36 inch deep
Orion has a 500.4 amp that is 4X62 at 4 ohms and is 13 inch by 10.25 by 2.25
Rockford fosgate has an Power Amp called Power 400.4 that sis rms 50 x 4 RMS at 4 ohms and is 13.35 inch (33.9 cm) long and 9.8 inch (24.89 cm) deep but the width is not available.
Hope this helps!
Old Jul 13, 2002 | 04:47 PM
ssainani's Avatar
I have a blaupunkt 4 channel amp in my truck and it's super small.......the size of 5 cd cases ontop of eachother?
http://www.ikesound.com/Prod_Details.asp?Prod_Id=216
That's the one....sounds great.
Old Jul 13, 2002 | 07:52 PM
AcurajL's Avatar
blaupunkt (sp?)
Notice that the blaupunkt is RMS 100X4 at 13.8 Volts which is highly unlikely that you will ever reproduce your battery's exact voltage at any time. Not that blaupunkt is bad but this rating is only good under certain circumstances. The JL is rated at 12-14 volts and has engineering that can supply more voltage and comlete the RMS wattage under certain conditions....
Old Jul 15, 2002 | 04:25 AM
autophile1's Avatar
Re: What's a Good small 4/ch amp?
What is your budget? the Helix (made by Brax) HXA400 MKII is a very nice amp (65wx4 rms) and it has a tiny footprint... Check it out at theautophile.com
Bryan
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
NSolace
Sep 3, 2015 08:02 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
