The Great Debate
Old Jul 13, 2002 | 11:17 AM
splitz's Avatar
The Great Debate
I have been plagued by this site and now the once dead and gone car audio bug has arisen. But now I am in the classic quandary of what sub and amp should I go for? What I have done is removed my torsion bars (im in the process of compiling instructions, but see http://www.acura-tl.com/forum/showth...threadid=43331 first), and now I am pondering fitting a 10" sub on the back deck, hoping that a sub fired into the cabin will sound better than one inside the trunk. Now its easy to say a W7 and some monster amp, but lets be realistic, if you fired a W7 into the cabin, would that be over kill? (if there is such a thing) But as most things in life money is my limiting factor, so I am putting a cap on the total of $500. While that is as much as I would like to spend, if there is a sub you think gives better bang for the buck let me know...ive got a lot of research ahead of me.
Old Jul 13, 2002 | 04:35 PM
Brewboy's Avatar
Keep in mind your strut force will wear down a bit after installing it.
The hole in the rear deck is 9" Are you planning the increase it for a 10" sub? There is not much room because of the middle seat belt tensioner. For the best SQ, I think the best bet is to physically seal the sub to the bottom of the deck using closed-cell polystrene insulation as a collor between your box and the rear deck. If there is a gap in there I don't know how much you've gained versus just sitting in the trunk. I have a CDT MS80 in a .45cf sealed box attached to the underside of the deck firing thru the stock hole. Pure SQ and gets loud enough for me, but I don't listen to rap/hip stuff.
The best bang for the buck is a 12" Adire Audio Shiva sub($125) in a 1.3cf sealed box with200-400 watts. Also their Brahma (10",12", 15") is in the super sub class with the W7 and others at a far cheaper price and has better SQ due to their new XBL2 technology. I have two Shiva's in my home audio system with only 150W each and they are tight and hit hard when needed. I can assure you they will compete with like subs costing 2-3 times as much. Adire has cheaper prices because they don't advertise like most other brand names. They are well known in the car audio forums and are developing a cult like status among those in the know.
Old Jul 14, 2002 | 11:38 AM
NSXNEXT's Avatar
Hey Todd, I'm just waiting for Austin to chime in how JL blows everything away in any class/price/category.
Old Jul 14, 2002 | 04:30 PM
splitz's Avatar
Brewboy, thanks for the info, I did some research on Adrie Audio and they seem very popular with the 12 volt crowd, but I went to check out thier web site and it looks like a fourth grader did it. Now I know that they are Car Audio people and not web developers, but it made me weary.
So after doing much research, I am leaning towards Audiobahn...to be specific the AW1008Q Sub and the A1300HCQ amp. Has anyone heard anything about this company good or bad? Thanks in advance.
Old Jul 14, 2002 | 08:20 PM
NSXNEXT's Avatar
splitz,
Check out www.ampmanaudio.com
And more importantly www.teamamp.com These guys love Adire...and Rainbow...and Brax....it goes on and on....
Old Jul 14, 2002 | 10:20 PM
preludeshfan's Avatar
before you buy any subs wait about 3 months for my new W7 killer subs. they will have a 3.6 inch xmax (about 34mm 1 way) they will have 50 pound magnets and handel about 1500 watts RMS. the first prototype will be a 12". i am expecting the release date to be in about 3 months.
these subs will be the officially highest tested xmax measured by Dumax Period!
Old Jul 15, 2002 | 07:27 AM
Brewboy's Avatar
So your the one! Are you using the XBL2 tech from Adire? I hear Adire is protoyping an 18" with 45-50mm xmax and XBL2.
Old Jul 15, 2002 | 08:22 AM
NO TC sounds builds my subs. they have had the record for the highest xmax for the last 4 years. i dont know anything about the adire sub. but i would be suprised if they have that much linear travel.
Old Jul 15, 2002 | 10:13 AM
NSXNEXT's Avatar
The 12" Adire Brahma did 32mm one way. Pretty damn close. And way cheaper than JL.
Old Jul 15, 2002 | 02:32 PM
Troy McClure's Avatar
If your getting a mono amp to run one 10"sub, I would reccomend the JL Audio Monoblock 250
Im runing one kicker comp vr 10 and it sounds great, much better than the infinity amp i had powering it previously.
Should be around $350
eastsideride
Oct 15, 2015 04:26 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
truonghthe
Oct 1, 2015 03:13 AM
Cexarin
Sep 23, 2015 07:43 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
