What does it mean to Bridge an amp?
Old Jul 9, 2002 | 07:56 PM
Crazy Bimmer's Avatar
Im looking for a amp thats 150x2 at 4ohm... but the one i want is 250x2 at 4 ohm bridged, can i set the gains lower so i dont blow the speakers?
Old Jul 9, 2002 | 09:20 PM
Rips CL's Avatar
Grls lov shiftn my stick
Bridging a stereo amplifier essentially turns two channels into one mono channel with greater power output. I think you are wrong when you said you would get 250x2 @4ohms bridged. You are really getting 250x1 @4ohms When you bridge the amp you will not have stereo, you will have one channel.
Old Jul 11, 2002 | 02:23 PM
PnoySport's Avatar
Sellout....
you wanna check what the resistance or ohms on the back of ur subs before u bridge the amp. make sure the amp can handle the bridge load u wanna go with. if it's too low of a resistance from the subs it runs the amp alot hotter and will thermal and clip and cut out.
Old Jul 11, 2002 | 11:12 PM
Austin519's Avatar
Rips CL:
Not necessarily true if you've got a 4 channel doing a 4->2 bridge.
Crazy:
Was that what you asked me all about on IM and did I answer it?
Austin519
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
STL TL-S
Sep 23, 2015 08:52 PM
