CL: What amp???
the box is made for 2000 watts? who built the box? and do you know if they built it to the Theile of the sub? or just a estimate and through in a slot. what gauge wire are you running to the massive amp?
if you want good power with a lil headroom, and dont mind spending money, this would be a nice one.
http://www.woofersetc.com/p-9187-lrx...amplifier.aspx
this for your battery or look for a xspower equivalent
http://www.woofersetc.com/p-4579-hc2...ower-cell.aspx
hope you are running the proper wire tho if you are upgrading for more power
Jimmay (09-25-2011)
SOrry man but that box looks small to me. And looks like a prefab also. Get a well built custom built and designed box and she will wang.
And lulz is like sayin lol but in a much cooler and hood way
cu0ngsayz (10-24-2011)
Your electrical system wont keep up. If youre reading the specs that means at 12 volts it will put out 2200 watts. I dont know the amperage draw on that amp but im guessing its quiet a bit. I have an AQ 3500d with an upgraded alt, XS d975, d2700, and just a regular deep cycle up front. My voltage would dip down into the 12s, dropping from 14.x.
Im gonna say youll need an upgraded alt, and at least a second battery, along with 0 gauge and your big three. Do it right the first time and you wont do it again.
Another thing, I agree with windowlickin. I had 2 of those amps and wish i still had them. Good amps and cheaper than a DD m3a.
cu0ngsayz (10-26-2011)
