CL: What amp???
Old Aug 12, 2011 | 06:13 PM
cu0ngsayz's Avatar
What amp???
alright all you audio heads i have a question for ya .... i got a Orion hcca 12.2 custom enclosure right now on a Massive N3 and was thinking about upgrading the amp for more power. what amp would be a good match with this sub? thanks for your time.
Old Aug 12, 2011 | 06:34 PM
cu0ngsayz's Avatar
And wats a good battery for this too
Old Aug 13, 2011 | 10:09 PM
mattastick's Avatar
What's your budget? For both the amp and the battery...
Old Aug 13, 2011 | 11:56 PM
eggyhustles's Avatar
that's a 1500w sub and your amp supplies 1400 @ 1 ohm.
You're good as far as power..your box is probably the culprit.
Old Aug 14, 2011 | 02:57 PM
cu0ngsayz's Avatar
i have battery now got it from my old jl setup.. i was looking into a massive audio N4.. budget wise? just give me some ideas on the amp maybe a few brands i can look into.
Old Aug 14, 2011 | 02:58 PM
cu0ngsayz's Avatar
i thought this is a 4000/2000 max/rms sub
Old Aug 14, 2011 | 03:03 PM
1500w
even if it were 2500w, you'd still be good as far as power goes.
Old Aug 14, 2011 | 03:22 PM
cu0ngsayz's Avatar
the box is custom made.. dont know much bout the box but it was made for this sub.. will get dimensions posted
Old Aug 20, 2011 | 06:06 AM
on1wheel01's Avatar
U need a proper box. Just cuz u have one that is suppose to be made for it most likely it's a prefab. Get a good builder to make u one. Then u will notice major output
Old Sep 2, 2011 | 05:26 AM
cu0ngsayz's Avatar
pretty sure this box isnt prefab. this box is a huge ass box. will get some dimensions soon... well i just installed the battery it was a stinger battery.
Old Sep 3, 2011 | 11:42 PM
fourthmeal's Avatar
Picture says 1000 words.
Old Sep 6, 2011 | 07:59 PM
cu0ngsayz's Avatar
23.25 width
16.5 height
18 depth
14.5x 2 port
I'll get pictures up.
Old Sep 7, 2011 | 02:45 PM
cu0ngsayz's Avatar
box
front
DEPTH
WIDTH
HEIGHT
SIDE VIEW
very little room.. if i push back anymore if will touch the back speakers
lmk what you think and if its the right size. according to orion manual this box is made for 2k watts...
Old Sep 14, 2011 | 02:12 AM
cu0ngsayz's Avatar
No one?!
Old Sep 14, 2011 | 03:00 AM
windowlickingood's Avatar
the box is made for 2000 watts? who built the box? and do you know if they built it to the Theile of the sub? or just a estimate and through in a slot. what gauge wire are you running to the massive amp?
if you want good power with a lil headroom, and dont mind spending money, this would be a nice one.
http://www.woofersetc.com/p-9187-lrx...amplifier.aspx
this for your battery or look for a xspower equivalent
http://www.woofersetc.com/p-4579-hc2...ower-cell.aspx
hope you are running the proper wire tho if you are upgrading for more power
Old Sep 20, 2011 | 08:55 PM
cu0ngsayz's Avatar
im running 2gauge jl audio wires.. then it splits to a 4 gauge to the amp and rear battery.
Old Sep 24, 2011 | 02:05 AM
so you have it split going to a amp and battery? you should have the main going strait to the battery then feed the amp off the battery.
Old Sep 24, 2011 | 08:38 PM
lulz@ recommending that audison amp.
Old Oct 20, 2011 | 09:47 PM
cu0ngsayz's Avatar
Ok I been on forums for a min but what the heck is lulz...
Old Oct 20, 2011 | 10:01 PM
cu0ngsayz's Avatar
Ohhh and is there anyway to recharge a dry cell battery? I got a local auto parts to test my stinger and they said it was drained...
Old Oct 21, 2011 | 06:16 AM
on1wheel01's Avatar
SOrry man but that box looks small to me. And looks like a prefab also. Get a well built custom built and designed box and she will wang.
And lulz is like sayin lol but in a much cooler and hood way
Old Oct 22, 2011 | 03:40 AM
cu0ngsayz's Avatar
Dude this box is small? Man it takes up most my trunk! But Yea imma try and sell this box and get a new one made... And hahaha ok got you about the lulz... But you wouldn't know about the battery would you? Hahaha
Old Oct 22, 2011 | 09:52 AM
on1wheel01's Avatar
NA man these boxes take up the trunk
My old durango
I have many more of my cl, but u get the point.
Old Oct 24, 2011 | 11:10 AM
cu0ngsayz's Avatar
My old durango
So you saying I need to build a box around that size for this sub? Im most likely upgrading my amp to a digital design M3a
Old Oct 24, 2011 | 01:16 PM
Jimmay's Avatar
I think what hes saying is you have to build it to spec, or what is optimal for your application( spl, daily).
Old Oct 24, 2011 | 01:25 PM
Jimmay's Avatar
Also be prepared to spend money upgrading your electrical if you go with that amp.
Old Oct 24, 2011 | 02:02 PM
the box is the right size for that sub. if you got a audioque aq2200d amp youre good.
Old Oct 24, 2011 | 05:42 PM
cu0ngsayz's Avatar
That amp only requires 12v to run the 2200v I need for the sub
Old Oct 24, 2011 | 05:52 PM
cu0ngsayz's Avatar
So I just need a more powerful amp you saying?
Old Oct 24, 2011 | 05:58 PM
Jimmay's Avatar
Your electrical system wont keep up. If youre reading the specs that means at 12 volts it will put out 2200 watts. I dont know the amperage draw on that amp but im guessing its quiet a bit. I have an AQ 3500d with an upgraded alt, XS d975, d2700, and just a regular deep cycle up front. My voltage would dip down into the 12s, dropping from 14.x.
Im gonna say youll need an upgraded alt, and at least a second battery, along with 0 gauge and your big three. Do it right the first time and you wont do it again.
Another thing, I agree with windowlickin. I had 2 of those amps and wish i still had them. Good amps and cheaper than a DD m3a.
Old Oct 24, 2011 | 07:12 PM
on1wheel01's Avatar
That amp would do great on upgraded ele as said.
Old Oct 26, 2011 | 12:43 AM
cu0ngsayz's Avatar
Yea but right now I can get a digital design and maybe the Orion at a really good cost.... Not sure if we can talk pricing n here but yea... Ive looked at the aq and they are going around 500 I can get the dd for about half that price
Old Oct 26, 2011 | 01:38 AM
cu0ngsayz's Avatar
So between a DD amp and a Orion hcca amp which one would be a better amp
Old Oct 26, 2011 | 07:08 PM
on1wheel01's Avatar
dd
Old Oct 26, 2011 | 07:51 PM
cu0ngsayz's Avatar
thanks. thats all i wanted to know. i'll be trying to do the big 3 again... if anyone can help me on getting detailed pictures of how to connect it that will be a big help.. if you havent read my other thread i tried but it failed. idk what went wrong
Old Oct 27, 2011 | 01:26 PM
on1wheel01's Avatar
U have a 2nd gen so i cant help u on that
Old Oct 27, 2011 | 10:39 PM
cu0ngsayz's Avatar
dd
anyone else agree with this? i should get a DD amp instead of a ORION HCCA amp
Old Oct 28, 2011 | 12:17 PM
Jimmay's Avatar
DD or an AQ 2200
Old Oct 28, 2011 | 02:40 PM
cu0ngsayz's Avatar
Thanks for your help guys
Old Oct 28, 2011 | 02:41 PM
cu0ngsayz's Avatar
Would ya know anything about batteries? My dry cell stinger battery is dead... I was wondering if I can use a portable battery charger to charge it back up and will it hold the charge
