What AMP?????
What AMP?????
I have an '01 acura CL type S In Nighthawk, and I had a question for all my CL owners out there?
I just bought the MTX thunder 6000 10" tri sub enclosure, and I needed to know what amp I should get for it?
I dont feel like spending too much for an amp, but I do realize it is neccesary to have a strong enough amp for three 10 inch subs,
any suggestions??????
any help would be greatly appreciated
the amp
Thnx for helping but what I really meant was what type of MTX amp should I get, there are many, I just dont know which one is sufficient enough for the three 10' subs
Guest
Posts: n/a
Re: the amp
Allerick B.
Amp
Thnx Woods, I actually ordered the MTX thunder 6500D, I was told it would be more than enough power for it, Do u agree with that, its specs are:
Power 12.5 VDC Input
2 Ohm Load 500 w x 1 Low Level
4 Ohm Load 250 w x 1 Hi Level w/ Smart
Crossover(s)
Power 14.4 VDC Low Pass 40Hz-200Hz -
2 Ohm Load 775 w x 1 Variable
4 Ohm Load 450 w x 1 RCA Output
Low Pass Only
Dimensions
(with ISO Feet) Other Features
Compression Circuitry
11.5" x 9.75" x 2.1" Thunder EQ
29.2cm x 24.8cm x 5.3cm EBC2 Port
Thnx again for your help :P
Crossover(s)
Low Pass Only
Dimensions
Everybody Wang Chung
That would work, but you could give it a LOT more power. Just don't try to push it too far or you could have problems. Let me know how it sounds, I have never heard the 6000's.
that system
Woods, My system is being installed next week on tuesday the 28th. I'll let u know how it sounds, I hope it is fucking awesome, but only time will tell, thnx again for all ur help, also do u have any Idea what kind of an auto place I can go to that will clear out my headlamp?
I wanted to clear the amber reflector out of them, meaning take the amber out, I didnt want to do it myself, so I was wondering if any place would do it for me
Thnx
Thnx
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
Pegon95
09-15-2015 01:54 PM
