What AMP?????
Old Feb 7, 2002 | 04:02 PM
Bafleisig's Avatar
What AMP?????
I have an '01 acura CL type S In Nighthawk, and I had a question for all my CL owners out there?
I just bought the MTX thunder 6000 10" tri sub enclosure, and I needed to know what amp I should get for it?
I dont feel like spending too much for an amp, but I do realize it is neccesary to have a strong enough amp for three 10 inch subs,
any suggestions??????
any help would be greatly appreciated
Old Feb 7, 2002 | 04:44 PM
Nicky Pass's Avatar
Fuct in the hed!
MTX AMPS..........match your amps with your subs!!!!!!!!!!!
Old Feb 7, 2002 | 06:15 PM
Bafleisig's Avatar
the amp
Thnx for helping but what I really meant was what type of MTX amp should I get, there are many, I just dont know which one is sufficient enough for the three 10' subs
Old Feb 10, 2002 | 10:57 PM
CL_Terminator
Guest
Posts: n/a
Re: the amp
what is the RMS rating of your 3 MTX subs, and that type of enclosure is it? Sealed, Ported, Bandpass? The amount of power required is contingent on the enclosure. Bandpass requiring the least, sealed requiring the most.
Allerick B.
Old Feb 11, 2002 | 10:40 PM
Woodsdaddy's Avatar
Everybody Wang Chung
If you were set on MTX amps I would get the Thunder81000D. The specs on your enclosure says 750 rms/1500 max. That Is a lot of power.
Old Feb 11, 2002 | 11:43 PM
Bafleisig's Avatar
Amp
Thnx Woods, I actually ordered the MTX thunder 6500D, I was told it would be more than enough power for it, Do u agree with that, its specs are:
Power 12.5 VDC Input
2 Ohm Load 500 w x 1 Low Level
4 Ohm Load 250 w x 1 Hi Level w/ Smart
Crossover(s)
Power 14.4 VDC Low Pass 40Hz-200Hz -
2 Ohm Load 775 w x 1 Variable
4 Ohm Load 450 w x 1 RCA Output
Low Pass Only
Dimensions
(with ISO Feet) Other Features
Compression Circuitry
11.5" x 9.75" x 2.1" Thunder EQ
29.2cm x 24.8cm x 5.3cm EBC2 Port
Thnx again for your help :P
Old Feb 12, 2002 | 12:20 AM
Woodsdaddy's Avatar
That would work, but you could give it a LOT more power. Just don't try to push it too far or you could have problems. Let me know how it sounds, I have never heard the 6000's.
Old Feb 12, 2002 | 11:34 AM
Bafleisig's Avatar
amp
Thanx again, i'll let u know how the setup sounds, it should be installed next week, so I will keep u informed
Thnx alot kid
Old Feb 18, 2002 | 04:51 PM
Bafleisig's Avatar
that system
Woods, My system is being installed next week on tuesday the 28th. I'll let u know how it sounds, I hope it is fucking awesome, but only time will tell, thnx again for all ur help, also do u have any Idea what kind of an auto place I can go to that will clear out my headlamp?
Old Feb 18, 2002 | 07:58 PM
Woodsdaddy's Avatar
What did you want to do to the headlights? Do they fog up?
Old Feb 19, 2002 | 12:18 AM
Bafleisig's Avatar
I wanted to clear the amber reflector out of them, meaning take the amber out, I didnt want to do it myself, so I was wondering if any place would do it for me
Thnx
Old Feb 19, 2002 | 10:27 AM
Woodsdaddy's Avatar
Oh, I have no idea who would do that. I would ask some auto shops that do custom work. That's the only thing I can think of.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
