wanted: electronics expert - valentine one help
Old Dec 20, 2004 | 09:22 PM
vp911's Avatar
Ok, here is what I want to do... I want to take the remote display from the V1 and be able to split it up...
I am not sure if this is possible... and if it is, how difficult is it to do...
I want to have the arrows in a completely different location in the car from the bogey counter and the signal strength...
is this possible? how would i do it?
Old Dec 20, 2004 | 09:24 PM
Dan Martin's Avatar
Photography Nerd
Anything is possible, but at a minimum you're going to need some soldering and desoldering skills. Basically you would just have to run wires from the lights to the circuit board. How far away are the lights going to be?
Old Dec 20, 2004 | 09:31 PM
vp911's Avatar
hmm less than 6 inches away?
Old Dec 20, 2004 | 09:32 PM
Dan Martin's Avatar
Photography Nerd
I don't see any reason why it couldn't be done.
Old Dec 20, 2004 | 09:43 PM
vp911's Avatar
i do... i dont know anything about electronics... lol
so... in theory, i would desolder each of the leds from the circuit board.... solder a wire between the original board and the led? or another board? im so confused...wishing somebody would do it for me
Old Dec 20, 2004 | 09:44 PM
Bass Mechanic's Avatar
should be easy, just what you said should work fine
Old Dec 20, 2004 | 09:46 PM
vp911's Avatar
you did the xm/ashtray mod for me a while ago! would you be able to do this?
Old Dec 20, 2004 | 11:24 PM
elduderino's Avatar
VP Electricity
You know, projects build character...
Old Dec 20, 2004 | 11:28 PM
slo007's Avatar
Master in Science
Old Dec 21, 2004 | 02:03 AM
Tsx536's Avatar
Rep'n Taxbrain.com
+1 That would be tight!
I already have the Valentine concealed display and I'm thinking about getting the Remote Audio Adapter and mount the 2 in the NOT an Ashtray. Then I'd put the V1 on my rear window and leave it there permanently. I have tint up, and I'm hoping it will protect the radar enough.
Do you guys think the heat reject/Uv protection of the tint will be good enough to protect the radar?
Old Dec 21, 2004 | 08:40 AM
you have a PM
Old Dec 28, 2004 | 08:54 AM
CynicalWry's Avatar
It's not easy at all to desolder the remote display. All the points are soldered by a machine, so you will need a very good iron and a nice stand w/ a maginifying glass.
Once you've actually desoldered the display, the rest is cake work. Just extend your wires and my your customization.
As for placement of the V1, i wouldn't put it on the rear deck. You've loosing alot of laser detection by doing such. Radar detection on the other hand won't be comprimised much.
Old Dec 28, 2004 | 12:30 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Placing the radar on the back windshield will effect your laser detection?
Old Dec 28, 2004 | 12:40 PM
vp911's Avatar
Yes, but it also cuts down on interferance from the sun. So it evens out. It does NOT cut down by a lot, infact very little. Read up on www.valentineone.com they have a section on mounting it - they explain the details there.
4drviper
Apr 23, 2025 07:13 PM
knight rider
Mar 4, 2016 08:59 AM
eastcoastguy
Oct 29, 2015 03:00 PM
ceb
ILX
Sep 27, 2015 10:56 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
