W7 Loud
Old Mar 18, 2004 | 09:23 AM
nucleusTL's Avatar
W7 Loud
Could the extreme deep bass of my w7, over time loosen bolts and cause more vibrations throughout my car? This is a serious question that may not be understood by someone not using a w7
Old Mar 18, 2004 | 09:46 AM
Sound Waves NJ's Avatar
5th Gear
it may you might want to look into a product called dynamat it is used to reduce vibrations caused by subwoofers or any other type of speaker
SOUND WAVES NJ
Old Mar 18, 2004 | 09:51 AM
nucleusTL's Avatar
yeah i got about $500 worth of dynamat extreme inthe trunk and the under the back seat area. But with this bass you need to wear yourseat belt or it will push you out of the seat. each piece of dynamat i put in actually makes it louder.
Old Mar 18, 2004 | 11:40 AM
Scott P's Avatar
Mobile Elec. Guru
the likelihood of it actually loosening bolts and what not is slim, but if you are really worried about specific bolts becoming loose you could always get some locktite (sp?) to spray on the bolts to help hold them in place, but the downside to that is, if you ever need to actually remove those bolts, it will be exponentially harder after adding the spray. In all honesty though you really are worring about nothing.
Old Mar 18, 2004 | 01:20 PM
dnd2984's Avatar
I think it will I have a w7 in a ported box and I had to get my rear glass resealed due to water leaks, Acura thought the car had been in a accident but it was casue of the bass. I really do think i am killing my car with teh W7 so I really dont turn the bass up all the way unless I am really pissed or something, ever panel in my car is flexing now to.
Old Mar 19, 2004 | 10:34 AM
nucleusTL's Avatar
Im glad to see someone understands
Old Mar 19, 2004 | 10:38 AM
ou sig's Avatar
Boomer SOONER
no cars are made for that kind of bass in the trunk. I only have 2 W3's with dynamat all over and my trunk sounds and looks like its going to explode.
Old Mar 20, 2004 | 04:18 PM
andytran's Avatar
i have a 12w7 powered by a jl1000 and i have my whole trunk dynamatted. it use to rattle alot mroe without the dynamat but its alot better. i dont know if the bass hits hard enough for it to loosen the bolts and stuff.
Old Mar 20, 2004 | 10:39 PM
dnd2984's Avatar
actually I did have one bolt come out, It was last year when I had my Solobarics and rockford amps. The screw inside the map light by the sunglass holder came loose. Dont know if it was casue of bass or not. Guy I know has 6 JL w6v2s powered by 3 kicker 1200.1 and his car hasnt had anything fall apart casue of bass. And its a everyday car to.
Old Mar 20, 2004 | 11:22 PM
ou sig's Avatar
Boomer SOONER
Holy Crap...can the guy hear anything? He must have a huge ass alternator to power those amps - stock couldnt cut it.
Old Mar 21, 2004 | 08:45 AM
dnd2984's Avatar
yes there is one big ass alt in the car, and six batterys, umm and there is 12 pairs of Kicker KX and 4 pair of R22 tweeters in the car to. The mid are powered by 3 800.4s, he also has a lift on the car for 24" dub spinners
Old Mar 21, 2004 | 10:05 AM
ou sig's Avatar
Boomer SOONER
HAHA wow I really want to see that ride. Does he enter alot of shows??? Thats amazing.
Old Mar 21, 2004 | 12:03 PM
vipvop's Avatar
All my screws in maplights / sunglass holders have come loose, and I'm only running a rockford fosgate 550 with 2 12" Kicker Comp VRs, I can't imagine what a decent system would do to the car...
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
DerrickW
Nov 15, 2015 05:52 PM
Skirmich
Oct 1, 2015 12:59 PM
merc009
Sep 29, 2015 03:06 PM
TL14
Sep 24, 2015 04:37 PM
