W7 Loud
W7 Loud
Could the extreme deep bass of my w7, over time loosen bolts and cause more vibrations throughout my car? This is a serious question that may not be understood by someone not using a w7
yeah i got about $500 worth of dynamat extreme inthe trunk and the under the back seat area. But with this bass you need to wear yourseat belt or it will push you out of the seat. each piece of dynamat i put in actually makes it louder.
Mobile Elec. Guru
the likelihood of it actually loosening bolts and what not is slim, but if you are really worried about specific bolts becoming loose you could always get some locktite (sp?) to spray on the bolts to help hold them in place, but the downside to that is, if you ever need to actually remove those bolts, it will be exponentially harder after adding the spray. In all honesty though you really are worring about nothing.
I think it will I have a w7 in a ported box and I had to get my rear glass resealed due to water leaks, Acura thought the car had been in a accident but it was casue of the bass. I really do think i am killing my car with teh W7 so I really dont turn the bass up all the way unless I am really pissed or something, ever panel in my car is flexing now to.
i have a 12w7 powered by a jl1000 and i have my whole trunk dynamatted. it use to rattle alot mroe without the dynamat but its alot better. i dont know if the bass hits hard enough for it to loosen the bolts and stuff.
actually I did have one bolt come out, It was last year when I had my Solobarics and rockford amps. The screw inside the map light by the sunglass holder came loose. Dont know if it was casue of bass or not. Guy I know has 6 JL w6v2s powered by 3 kicker 1200.1 and his car hasnt had anything fall apart casue of bass. And its a everyday car to.
DerrickW
11-15-2015 05:52 PM
