Viper 550 ESP...
Old May 6, 2004 | 10:08 PM
Ant7701's Avatar
Sweet as Gold
Viper 550 ESP...
Hey...who here has one of these remote starter/alarm systems in their 2nd gen cl. How do u like it. Can the trunk opener be programmed??Any pros and cons to it. Also...can any upgradable newer remote transmitters be programmed to it.
The reason is I have a DEI add-on remote starter system but I just got a 550 ESP for free and am considering installing that instead. Please so any feedback would be appriciated. Thanks in advance!!
Old May 7, 2004 | 07:54 AM
fuzzy02CLS's Avatar
I had it. Worked fine. Trunk release does work. You can program alot of things if you have the DEI bitwriter. Only issue I had was the factory disarm wire was in the drivers door by the secruity light. Installer had to ground it out for the factory system to shut off.
Old May 7, 2004 | 08:17 AM
NJ_CLS_driver's Avatar
Mine works fine with the Factor Alarm. So both Arm and DisArm at the same time
Old May 7, 2004 | 02:19 PM
Vector02's Avatar
What wire is the factory disarm wire??? I can't find it for the life of me!! I always have to disarm my 791vx before i can remote start and it pisses me off.....
Can you ask your installer what wire it was specifically???
Old May 7, 2004 | 02:31 PM
fuzzy02CLS's Avatar
Don't remember what color it was, Blue I think? It was in the drivers door by the factory security light. Maybe take the panel off & check?
Old May 7, 2004 | 03:40 PM
Vector02's Avatar
I thought it was blue/white... but i've tried hooking up the factory disarm wire out of the alarm to 2 different wires back there by the tumbler, and nothing has worked.......
Old May 7, 2004 | 04:41 PM
Ant7701's Avatar
Sweet as Gold
OK...this is news to me...what exactly do u guys mean by factory disarm wire???What do I have to do w/ it and why???Also...do I really need the DEI bitwriter or can I program all of the functions w/ the valet switch. If not where do I get a bitwriter. Also...i've seen many remote starts w/ a wire wrapped around the key illumintator to pick up the immobilizer signal. what exactly is done by this..do I still need an extra key in the car???
Old May 11, 2004 | 07:14 AM
fuzzy02CLS's Avatar
Most aftermarket alarms have a factory disarm wire on them. This wire is tapped into the factory alarm to automaticly disable the factory alarm when you use the aftermarket key fob. This in a sense bypasses any factory alarm the car has. This is any alarm install, not just remote start. You can program some things with the valet switch, but not everthing. Your wire around the key I don't know about. That seems to be a rigged method. You do need a key in the car. It has to be programmed, but doesn't have to be cut. It can be a blank. Another way is to get a factory bypass for the key. DEI makes some that let you splice into the factory alarm so you don't need the key in the car. The have this for GM & some Fords. Not sure if it is made for Acura.
Seems each CL/TL is a little different or maybe the installers just install them different. In my 02 I had the only way to get the factory alarm to disable was to ground out the wire by the door lock. Even though the right disarm wire was tapped. Others had no problems. You know if it doesn't work if when you remote start the car with out unlocking it & the factory alarm goes off.
Old May 11, 2004 | 07:44 AM
withoutcomp1's Avatar
Just ground the wire at the at the factory hood latch switch, bye bye factory alarm! why do you need it if your adding an aftermarket anyway? plus the factory fuel kill will still work. just my 2 cents. i am an installer anddid plenty of cl tl's.
Old May 11, 2004 | 08:17 AM
OUTRAGEOUS CL TYPE S's Avatar
1 Phat CL !
hey ant i got, had it for 2 years, proxy sensor, trunk open, they who shabang. awesome range!!!
Old May 11, 2004 | 10:45 AM
Vector02's Avatar
Where is the hood latch switch?
Old May 11, 2004 | 05:06 PM
Titand19's Avatar
East Coast Boost.!
Ant, i might be able to get the bit writer if you need it.
Old May 11, 2004 | 11:07 PM
Ant7701's Avatar
Sweet as Gold
OK guys...I'm going w/ the viper 550 esp. I'm also gonna have it professionally installed too so I don't have to deal w/ the headache. However the one i have is used and I don't have a manual for it. Can someone please give me a list of the programmable options that I can ask to be programmed when I get it installed. Also can I purchase a pager remote transmitter for this system.???Help me out guys..
Ant7701's Avatar
Sweet as Gold
Ohh...thanks alot Andy
Ant7701's Avatar
Sweet as Gold
...and everyone else that responded!!
Old May 13, 2004 | 01:08 PM
InstallerJohn's Avatar
98 2.3cl
just go to DEI's website (directed.com) and you should be able to print out a full installation manual for the 550. You can add on and FM Pager to the 550 pretty easily I want to say the model # is 795T for just a beeping pager ( not positive though), I would get it on ebay if I were you. Will be about 60-70% cheaper than buying it at a store, or you could go to a circuit city in your area and if they have it, it will be priced down to cost becuase Circuit city is no longer carrying DEI products. But, they may not have it in stock.
Old May 13, 2004 | 05:43 PM
Ant7701's Avatar
Sweet as Gold
Hey installer John...I went on directed.com and can't find any info on the 550 at all. I even used the search and still can't find anything. Do u have a link for me...also a link for any info on the pager remote transmitter??
Old May 13, 2004 | 11:27 PM
98 2.3cl
For the owners guides go to http://www.directed.com/guides/ogs.asp.
For the pager info go to http://www.directed.com/security/access/oaccess.asp , It's the 795t and listed for $207. I sold a customer one last week for $59, that's wholsesale price and what all circuit city's have them marked down to. The hard part would be finding one that has it in stock ebay would have them for about the same price.
gatrhumpy
19
Dec 31, 2015 04:22 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
Sep 14, 2015 10:10 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
