Video in navi???????????????????
Old Aug 9, 2001 | 09:18 AM
Slammed99TL's Avatar
if i use the RGB-1 decoder thing will i loose my navigation and only have video or is there a switch or something to go from navi 2 video.
thank you.
Old Aug 9, 2001 | 11:09 AM
SteveStMS's Avatar
You can use a 4PDT switch (sold on-line). When using this switch, the RGB1 decoder is mounted behind the dash.
OR
Use a 4PDT relay 12volt (sold at Radio Shack). The RGB1 and relay are mounted back with the navigation computer and wired up to a single pole dash mounted switch.
Old Aug 9, 2001 | 04:26 PM
isaaktnt's Avatar
Hi Steve
What is the advantage of the relay?
Old Aug 10, 2001 | 02:18 AM
Bitium's Avatar
Retired MOD
I need one of those
Old Aug 10, 2001 | 09:41 AM
SteveStMS's Avatar
The relay can be easier to install in the trunk than pulling your dash apart. You basically buy the relay and socket from Radio Shack and pre-wire the AVC-RGB1 to the correct socket pins. Also hook power wires on to energize the relay. This will leave you with 2 sets of 4 terminals to be connected between navi computer plug and wire harness going to the display unit. "Intercept" the 4 wires (White,Red,Yellow and Green) on the middle black plug of the navi computer.
Old Aug 11, 2001 | 11:07 AM
Jessie888's Avatar
Hi! I also am looking around of a DVD Player and Navi System in one. Is it worth to buy the system all in one or just buy the Player or Navi system then upgrade.
Old Aug 13, 2001 | 08:49 AM
HEY STEVE
Hey STEVE,
can we hook up a laptop somehow to this decoder ? and see the laptop or do we have to get any other part ??
Old Aug 13, 2001 | 09:39 AM
ArN 2000 TL's Avatar
Moderator Alumnus
Re: HEY STEVE
Originally posted by goodbadmas
Hey STEVE,
You can hook up just a laptop to it and see the display as long as your laptop has video out. It will be incredibly small though. I used my laptop as a testing tool once i installed it.
Old Aug 13, 2001 | 10:25 AM
LAPTOP
Actually, I do have 2 5.6" in the back of the headreast and just thought that may be .. i can do something neat with hooking up my laptop ... and hook up those 2 screens with the navi decoder and i dont' know ! still thinking .. i will talk to ron about it !
Thanks a lot for the info though !
Old Aug 13, 2001 | 11:54 PM
kensteele's Avatar
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
lanechanger
Oct 13, 2015 10:56 AM
Cgannotti
Sep 25, 2015 05:04 PM
