Upgrading the alternator...
Old May 16, 2003 | 07:12 PM
I just got my new 180amp alternator and new 4 gauge alt. cable. I was looking at how the cable runs from the alternator and saw that it goes to the fuse box and is fused at 120amps. Can this fuse be upgraded or should I just run the cable directly to the battery? I wouldn't feel comfortable doing that incase the voltage regulator went in the alternator and blows up the battery.
Mike
Old May 30, 2003 | 04:49 AM
systek's Avatar
that fuse is for the max load of the car but does the same thing that the underhood audio fuse does. no one ever messes with that fuse for obvious reasons. that is the reason there are so many under hood watertight fuse holders you can buy specifically for an audio system. just buy one of these and run the wire directly to the battery.
Old May 31, 2003 | 11:56 PM
Thanks Systek I am going to do that. I'll just leave the other wiring tucked away so I can reuse it one I get rid of the car or alternator. Should I go with a 200 amp fuse if the Alternator is 180 amps? The acura fusible link is 120 amp and the alternator is 105 amp rated so I think 200 should be good .
Old Jun 1, 2003 | 12:56 AM
systek's Avatar
the amp rating should not exceed the rating of the wire you are trying to protect. also, the amplifiers or other electronics being supplied by that power cable should not exceed that max amp rating either.
mlody
Dec 4, 2019 02:11 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
thegipper
Sep 28, 2015 01:01 PM
