Unlock code for factory stereo doesn't work
Old Oct 25, 2008 | 11:54 AM
Bogdan TL's Avatar
Yes, i've used it in the past. One time I changed my battery and I had to input the code and recently i've changed the high beam light bulbs and had to remove the battery.
But last night when I tried to start my car it went dead all of a sudden. Opened the hood- a battery contact came loose - my bad - did not tighten it good enough.
When I tried to input the code - it started giving me errors - one after the other -" ERR 1 " - so forth.
Unplugged the battery again for 10 min - same story
Acura dealership doesn't know what else to do
Fuses are intact - it ejects CD's
HELP
Old Oct 25, 2008 | 02:52 PM
LacViet's Avatar
291hp & 245 tq @ 3.5psi
Read this thread will help you to make it work again:
https://acurazine.com/forums/2g-tl-problems-fixes-117/radio-code-doesnt-work-602128/
Old Nov 2, 2008 | 02:28 AM
1oooop's Avatar
6th Gear
I suggest you take it to a mechanic... he/she will then go to the dealer and get the code for you...(btw... make sure he is doesn't work for a major corporation... because they usually charge for it)
Old Nov 2, 2008 | 10:53 AM
nayaab88's Avatar
take out the antenna... read the thread that was posted above.... it works like a charm
Old Nov 2, 2008 | 02:33 PM
fsttyms1's Avatar
Why would he do that?? He HAS the code. The radio isnt accepting it.
Unplug the radio antenna from the back of the radio turn the key on and enter the code. If it accepts it then put the antenna back in.
Old Nov 2, 2008 | 04:32 PM
JDM Inspired's Avatar
The Antenna must be unplugged for the code to work, well for mines and hopefully for yours lol.
Old Nov 4, 2008 | 09:06 AM
lokee99's Avatar
I'm stock and hating it.
I didnt have to unplug my antenna for it to work. You might not have the right code. I took my radio out and took it to the dealer and they searched the right code for me for free. Just a sugesstion.
Old Nov 4, 2008 | 11:09 AM
rob-2's Avatar
https://radio-navicode.honda.com/
Old Nov 17, 2008 | 08:30 PM
gold2003tl (90)'s Avatar
2003 TL-p
i really suggest removing the Bose cd changer and putting an aftermarket. there are threads hear that tell u how to get the sub to work with an after market. if the Bose unit you all have now isn't jamming cd's it will sometime. mine kept jamming the cd's, and i had to bang on the dash to free them up.
its just i have had so many problems with that stock Bose cd unit i highly suggest removing it before you get more problems. i mean if you cant get the code to work just get rid of it.
hope you dont run into any more problems
AndrewS
19
Mar 14, 2024 06:59 PM
handsom-hustla
Nov 13, 2015 05:04 PM
scionxb3003
Oct 2, 2015 05:50 PM
acurajj
Sep 19, 2015 03:47 PM
Gianni Formica
Sep 7, 2015 08:28 PM
