TSX-RCA wall jacks for IPOD install?
Everyone,
I am interested in putting the RCA wall jacks in my console for my IPOD. I went to Radio Shack and saw that they are Solder only. Are there ones where I would not have to solder. I would really like to not have to do this. If I do have to solder them should I solder them directly to the GLI cable or should I connect the another smaller cable to the GLI? I would appreciate some recommendations or pics. Thanks
I have seen some pictures that Schiaoll (sp) had done to his center console bin and would ideally like to have this setup. Did buy the female adapters at Radio Shack and solder them onto wire? Or did he adapt a wire with A/V female adapters to put into the console?
buy a wall plate with RCA jacks and unscrew them. drill holes into the TSX and then screw the RCA jacks into that hole (like the one in the wall plate)
let me know if you need a more detailed explanation. be careful where you place the RCA jacks so that your cupholder can still open and close.
this is a requote for a thread i started a while back here..
https://acurazine.com/forums/audio-video-electronics-navigation-22/alternative-aux-input-snhond3-292052/
Originally Posted by palidanx
I've noticed that a lot of people out there are wiring from their snhond3's an rca audio pair to their center console. And then when they hook it up to their ipod, they use a mini-y cable to connect it to the ipod (rca to 3.5 mm jack). Even though I do have a dension icelink to hook my ipod up to the car, I wanted to add an additional audio input capability to the car (i have a 3-way audio switcher that elduerdino found for me one day).
I was thinking why not just create a 3.5 mm jack straight up instead of wiring two rca jacks.
What I did here was attach a 3.5 mm stereo jack plug to the cigarette plastic piece of the center console. I then bought speaker wire and soldered the rca jacks and the 3.5 mm stereoe jack plug.
I just made a small hold in the plastic piece to put in the 3.5 mm stereo jack.
Front view of the plug
Picture of it mounted
Front view
This way if i want to hook a laptop or another mp3 device, I just need a male to male 3.5 mm stereo cable. No need to bother with mini-y cables are taking apart the center console
Front view
That looks good. I might have considered doing it that way if I had seen it. I like that you used the power source plastic trim for a mount as well. I was a bit hesitant to drill through the actual console in case that if I ever wanted it to look stock again in the future I would have to replace the entire console. With the power source piece of plastic, if you want the car to appear stock in the future all you have to do is replace that one small piece.
Vejey Gandier
Sep 12, 2015 08:59 PM
ivegotthenav
Sep 11, 2015 07:51 PM
spoiler900
Sep 10, 2015 01:06 PM
