CL: Too Many amplifiers ?
Old Jun 14, 2009 | 05:37 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
If I was running too many amplifers with not correct electrical,in order,what parts of my system would fail first.AMPS,SUBS,ALT,BATTERY,etc.
Old Jun 14, 2009 | 06:25 PM
mattastick's Avatar
Looks like you got the order right already... Amps are likely first, then subs, then alt then batts... I dunno about the alt and batts part though....
Old Jun 14, 2009 | 08:56 PM
just wanted to know cuz when I hook up the 2nd amp I know It's gonna be hard not to see what they can do,till I get the electrical right.
Old Jun 14, 2009 | 09:21 PM
mattastick's Avatar
Get 2 volt gauges, and attach 1 to each amp... Then you'll be able to see what kind of voltage drop you're getting... That's the best way to make sure you're not tearing shit up... Then, you'll also be able to tell how much of a difference batt/alt upgrades make...
Old Jun 15, 2009 | 07:55 AM
on1wheel01's Avatar
+ 1 on that. I bet ur alt will go out 1st thats what mine did, granted my amp is a power hungry skank. The bioch of a alt was only a year old.
Old Jun 15, 2009 | 11:47 AM
Any pics or links to the gauges your talking about.Sounds like somthing I should look into.what # of volts could I get away with safely?
Old Jun 15, 2009 | 04:51 PM
mattastick's Avatar
http://www.hifisoundconnection.com/S...id/0/SFV/30046
Anything like that would work... Just make sure it's set correctly using a DMM. You should be alright into the 11's, but if your voltage is dropping out of the 12's, turn it down!!!! I personally didn't run my amp below like 13.5 when I had everything hooked up
4drviper
Apr 23, 2025 07:13 PM
Feb 25, 2020 09:57 AM
tpraka300
3G MDX (2014-2020)
57
Dec 10, 2018 02:17 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
spdy0001
Sep 30, 2003 12:12 PM
