TL 2002 - Radio/Audio System Block Diagram
Old Jun 17, 2002 | 05:53 PM
Does anyone have a block diagram/wiring schematic of our radio and audio system? Just found out that we had an actual amp behind the trunk liner. I am curious now as to how it is wired so that i can select a replacement system.
Thanks for the help.
Old Jun 18, 2002 | 08:15 AM
Iggy's Avatar
Retiree,
The amp you are refering to is actually on the pax side behind the rear seat and that ONLY drives the rear sub. I'm pretty sure it gives 100 watts output.
Schematic? maybe this would help:
diagram
What exactly are you planning to do? If you are going to add an outboard amp or just replace the speakers here are some worthwile recent posts:
link 1
link 2
Iggy
Old Jun 18, 2002 | 03:43 PM
Thanks for the help. I was just curious at this point. Maybe just adding a DVD player while retaning the existing Acura equipment somehow.
Old Jun 18, 2002 | 04:49 PM
shawhite's Avatar
retiree if you are just trying to get the audio to play thru the stock speakers the easiest way would probably be to use a fm modulator but of corse you will sacrafice sound quality...
Old Jun 18, 2002 | 07:03 PM
Thanks for the hint. I will consider one of those.
TypeS860
Jan 10, 2026 11:11 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
maharajamd
Console & Computer Gaming
Sep 24, 2015 03:31 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
