Tapping in stock amp? help!
Old Oct 26, 2003 | 11:00 AM
aGUYfromHARLEM's Avatar
I have a 1 generation CL and I also have a JL 250/1 and 2 JL 12" subs...someone said i can tap into the stock amp and hook up my JL amplifier...if so, does anyone know how i would go along in doing this, thanks alot...
Old Oct 26, 2003 | 11:48 AM
GSteg's Avatar
i would just get a line-out convertor from www.davidnavone.com instead of using the high-level input from your amp. why? because if u use the high-level input, there is a chance you will have high floor noise. a LOC is pretty cheap and easy to install. that why you can run RCA's to the amp.
Old Oct 26, 2003 | 12:29 PM
proaudio22's Avatar
-S namyaC-
If the amp had true "hi-level"inputs, it's the same damn thing as using a Line Out Converter, it's just done inside the amp. You actually have more of a chance for a higher noise floor using a LOC b/c the RCA wires you use might pick up excess noise, etc.
Old Oct 27, 2003 | 07:21 AM
hinrgdj's Avatar
The LOC's that David sells use transformers to isolate the signal. You will NOT have any ground loop/noise problems from the input to the amp.
Old Oct 27, 2003 | 07:23 AM
proaudio22's Avatar
-S namyaC-
Yea, ya still could. The isolation in the LOC only prevents noise from the speaker leads. If the RCA connecting wires are cheap and/or pass/cross other power wires, you could still have noise.
Old Oct 30, 2003 | 06:37 AM
Mitchel's Avatar
broke ass fawker
Re: Tapping in stock amp? help!
Personally... i don't think you need to go through your stock amp. If you have an after market cd player then just run it from you cd player. I did this in my 97 CL and had no trouble at all. any more questions PM me
4drviper
Apr 23, 2025 07:13 PM
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
