Tapping in stock amp? help!
I have a 1 generation CL and I also have a JL 250/1 and 2 JL 12" subs...someone said i can tap into the stock amp and hook up my JL amplifier...if so, does anyone know how i would go along in doing this, thanks alot...
i would just get a line-out convertor from www.davidnavone.com instead of using the high-level input from your amp. why? because if u use the high-level input, there is a chance you will have high floor noise. a LOC is pretty cheap and easy to install. that why you can run RCA's to the amp.
-S namyaC-
-S namyaC-
Originally posted by hinrgdj
The LOC's that David sells use transformers to isolate the signal. You will NOT have any ground loop/noise problems from the input to the amp.
broke ass fawker
Re: Tapping in stock amp? help!
Acura604
20
08-05-2017 12:55 AM
09-25-2015 06:14 PM
4drviper
09-23-2015 09:00 PM
