system help
Old Aug 18, 2001 | 02:58 AM
Crav4Speed's Avatar
Question system help
im getting ready to install my new system ( MB components front and rear, 2 10" Kicker S10L7, Fockford Fosgate Punch 400.4 and 800.2)
my questions are:
1. the 2 amps have speaker level inputs and RCA inputs so which would be better to use, the RCA's with an added LOC or the speaker level inputs disregarding the addition of a LOC?
2. if the LOC is better, should i use a 2 channel coming from the stock sub wiring or a 4 channel coming directly from the headunit?
help is greatly appreciated and deperately needed
Old Aug 19, 2001 | 03:39 AM
Crav4Speed's Avatar
hello?
anyone??? Ron? Dhiren? (if I may)... I have been doing searches for the past week resulting in nothing but confusion... HELP!!!
Old Aug 19, 2001 | 06:51 AM
ghost31711's Avatar
RCA inputs are better.....
are you using the stock headunit? i did a little reserch and found the audio control HPX to be a great conpanion for stock headunits, it converts speaker line to RCAs and it also gives a greater voltage output towards your amp,(up to 13 volts!!!) i'm getting my and i will have it installed within 2 weeks, why dont you let me try it out...and i'll tell you if its good or not..... or ask streeteffectz..... he has exprience with it ....
Old Aug 22, 2001 | 01:25 PM
Crav4Speed's Avatar
cool Ghost... thanx for the help... I'm gonna be installing it hopefully within a week also so let me know how it turns out... also can you tell me where you hooked it up to? i mean from the headunit or from before the factory sub amp?
Old Aug 24, 2001 | 05:00 PM
Crav4Speed's Avatar
BUMP
can anyone else help me out?
Old Aug 24, 2001 | 05:07 PM
Brewboy's Avatar
RCA's are better. Since your upgrading all your doors, use a 4-channel LOC at the HU. From the LOC feed your 4-chanel amp and use a Y-adapter at at the same amp to feed your sub amp.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
