Nsxnext
Old Aug 24, 2001 | 05:28 PM
Brewboy's Avatar
Nsxnext
Got the Brax's installed vertical. Had to raise them up about 1/2" above the stock speaker location to clear the ridge on the interior door panel. Had to cut the inner door panel a little more to raise the door hole up a bit. Used 3/4"MDF baffle with some sanding on the back side to compensate for the raised areas in the door. If you can get the face of the baffle to about 2-7/8" away from the glass measured on the bottom of the speaker cut-out, you should be fine. Overall, I think I increased the radius of the door hole by about 3/4". The cast baskets are beefy and they have tabs in each quadrant so they need a big hole.
But they are a singin' now. They are so tight!! Seamless integration with the MS80 and no point of origination in the lowend.
When you getting your stuff and when is Ron gonna work his magic. Don't know what I'm gonna do about my sub box- it just sorta hangs down like a sore thumb. I have no creativity when it comes to this stuff so I guess I'll just box it in with some felt.
Old Aug 24, 2001 | 07:21 PM
NSXNEXT's Avatar
Todd,
I was wondering when you were gonna post. I figured I'd leave you alone in case you were having problems. Sounds like it came out great. Any pictures
Well I think I may just have Ron mount the tweeter separately instead of going through all that trouble. We'll see. He's the zen master.
I ordered my stuff last week. Kirk said it should start to trickle in soon. It better, I'm getting married in two weeks then off to Hawaii. I wanna hear some kickin tunes in the TL before I leave.
Glad everything worked out for you.
Jspecinspire
Mar 16, 2003 07:50 PM
stenoslave
Wash & Wax
Jun 7, 2002 10:37 AM
snook789
Sep 20, 2001 07:53 PM
