system help
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
im getting ready to install my new system ( MB components front and rear, 2 10" Kicker S10L7, Fockford Fosgate Punch 400.4 and 800.2)
my questions are:
1. the 2 amps have speaker level inputs and RCA inputs so which would be better to use, the RCA's with an added LOC or the speaker level inputs disregarding the addition of a LOC?
2. if the LOC is better, should i use a 2 channel coming from the stock sub wiring or a 4 channel coming directly from the headunit?
help is greatly appreciated and deperately needed
my questions are:
RCA inputs are better.....
are you using the stock headunit? i did a little reserch and found the audio control HPX to be a great conpanion for stock headunits, it converts speaker line to RCAs and it also gives a greater voltage output towards your amp,(up to 13 volts!!!) i'm getting my and i will have it installed within 2 weeks, why dont you let me try it out...and i'll tell you if its good or not..... or ask streeteffectz..... he has exprience with it ....
cool Ghost... thanx for the help... I'm gonna be installing it hopefully within a week also so let me know how it turns out... also can you tell me where you hooked it up to? i mean from the headunit or from before the factory sub amp?
RCA's are better. Since your upgrading all your doors, use a 4-channel LOC at the HU. From the LOC feed your 4-chanel amp and use a Y-adapter at at the same amp to feed your sub amp.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
