Switched power?
Old Nov 20, 2003 | 10:30 AM
VTEChump's Avatar
Switched power?
Anyone know if there is a wire I can tap into to get switched 12 V power somewhere in the trunk???
Old Nov 20, 2003 | 12:14 PM
Iggy's Avatar
you can tap off the sub amp behind the rear seat on the right. The orange wire. it's a fairly low power wire and it does not work for some amps that require more power for the trigger.
good luck
Iggy
Old Nov 20, 2003 | 08:25 PM
9th Gear
Iggy:
On the diagram you posted do you know if the 'Woofer Speaker' connections are for the rear door speakers? And are the 'Bass' inputs the leads to the sub?
If I wanted to put my own amp and sub in, could I any of the wires in that connector as my RCA input?
Thanks for the help.
TG
Mike Pilipenko
Mar 26, 2024 09:21 PM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
eastcoastguy
Sep 23, 2015 06:29 AM
