MISC: switchbacks
Old Sep 11, 2009 | 02:35 PM
SpeakandBeFree's Avatar
switchbacks
the amber light doesnt work on my switchbacks, only the white light, does any one know whats wrong?
Old Sep 11, 2009 | 11:53 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Both sides or just one? Did you try to turn the bulbs around ?Do you have the load eq's installed,and corectly installed ?
Old Sep 13, 2009 | 10:19 PM
one side, and tried turning the bulbs around, and yes i have the resistors correctly installed
Old Sep 13, 2009 | 10:28 PM
I guessing you also swaped sides to rule out bad bulb....
Then if everything else is wired correctly try swaping the working sides eq to the none working side to rule that out.
Old Sep 14, 2009 | 01:17 AM
ballersonly's Avatar
where did you get those from?
Old Sep 14, 2009 | 05:04 PM
tried that, and still same problem, so most likely i need a new bulb?
got them from autolumination
Old Sep 14, 2009 | 05:30 PM
What eq's did you use ?I heard the 50w were the one's that should be used.
Old Sep 15, 2009 | 08:47 PM
50w ones... people on say that the circuit board failed... i wanna know how that happened
Old Sep 15, 2009 | 08:58 PM
did it get wet?
Old Sep 16, 2009 | 05:59 PM
Originally Posted by richardparker
did it get wet?
i dont think so, there is a little between my headlights and my car and it did rain, so maybe it did get wet
TLrascal
Aug 3, 2018 11:00 PM
baowheezy
Sep 22, 2015 09:03 PM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
manolo
Jun 4, 2009 08:16 AM
GoldnKnight22
Sep 29, 2008 07:50 AM
