Subwoofer dead?
Old Oct 1, 2008 | 12:31 AM
Palayah8ta's Avatar
Ciao Pho Eva eva
Subwoofer dead?
So i bought a 8" JL w3 from a co-worker with a 800 watt Pioneer mono amp, and 20 mins after i installed in on my new Pioneer head unit it stopped working.
So i plugged my friends amp to my sub and still nothing..
Now call me old school but when a sub blows or dies, it still makes some noise.. am i wrong?
Old Oct 1, 2008 | 01:44 AM
ABP1TSX's Avatar
i would first check the wiring in the box to see if it came undone from the terminal or speaker. If it was playing fine and wasnt being pushed hard, i wouldnt think it would be blown. Unless the tinsel leads broke or the coil is completly fried then yes it would make some type sounds.
Old Oct 1, 2008 | 08:28 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Check the fuses on the amp, etc. Does the amp come on? Does it have a green light of any kind? You may have triggered the protection on the amp
Old Oct 1, 2008 | 11:40 AM
Palayah8ta's Avatar
Ciao Pho Eva eva
The amp has a blue indicator light that is on.. i checked all the fuses and there fine. I even took the case off the amp. the system board looked fine, no caps peaked, nothing burnt up.
The sub wiring is a little wierd.. i didnt touch it but when i looked at it there was 4 connectors..
Old Oct 1, 2008 | 09:26 PM
Osamu's Avatar
do you have another cheap speaker you can hook up to the amp to see if everything is working from there forward.
depends how you blow the sub whether it'll make a sound. Try pushing on the cone lightly, and listen for any scraping, would usually indicate a blown VC.
Old Oct 1, 2008 | 11:33 PM
phipark's Avatar
Not Asian
You can blow a sub without sound because sometimes the amp will shut off. What happened on a Solobaric L7 of mine, it had a "bad" spot on the voice coil and was rubbing against the magnet. You might be able to slightly push on it and see if you can feel it rubbing.
Old Oct 2, 2008 | 10:07 AM
Costco's Avatar
if you have a multi-meter, check the resistance on the speaker terminals. I think JL subs are 3-ohms (someone correct me if I'm wrong) if its really high chances are the sub is basura
Old Oct 2, 2008 | 12:54 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
Is this a common thing to happen? i thought JL is supposed to be good stuff?
Old Oct 2, 2008 | 01:02 PM
Audiovibe-Mike's Avatar
12volt Technician
JL is good but distortion will kill any speaker. When distortion occurs your voice coils will heat up at an enormous rate and likely burn up. When you were playing it did it sound clean. Lightly, again ill say LIGHTLY press on the cap in the middle of the sub. if you hear a loud scraping noise the coil is fried, make sure you push lightly and evenly (if you push off centre it may still scrape a little but not as loud). the reason there are 4 wires in the box is because its a dual coil sub, you must check both coils and they should both read around 3 or 4 ohms. if one coil is gone the sub is pretty much garbage. disconnect the sub from the amp and tap a 9volt battery to each coil. red and black. if the speaker "pops" a little it should still be okay. If you need more help PM me, I'm a electronic accessory technician and Ill be glad to help.
Edit: Does your sub smell like burnt electronics??? Believe me youd know if it did.
Old Oct 2, 2008 | 03:19 PM
illmat1k's Avatar
Thass Wassup!
JL is ok. There are better companies that produce much more better products than JL. They sound cleaner and have better power handling than JL. JL is just overpriced. And no, its not "you get what you pay for."
Old Oct 3, 2008 | 11:03 AM
theCARdiologist's Avatar
For starters, what's the Pioneer amp putting out? The 8W3 is 150watts RMS
Old Oct 6, 2008 | 12:23 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
I ended up stealing my friends Subwoofer and it worked with my amp in my car..
How the fuk did i blow the speaker?
Old Oct 6, 2008 | 01:54 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
http://cgi.ebay.com/INFINITY-850W-RE...ayphotohosting
would this be a bettter fit?
Old Oct 6, 2008 | 02:43 PM
(Mid-Atlantic)
That infinity is a good choice, JL's are good, but are not rated correctly
Old Oct 7, 2008 | 06:35 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
Lol i plugged in the new Infinity speaker and its working at like 1/15th strength.. any suggestions?
Old Oct 8, 2008 | 03:30 PM
(Mid-Atlantic)
Check all the settings on the amp, low pass filter, gain, make sure everything is set to make the amp work as a bass amp, also are is it a multichannel amp? Are you bridging it? How are the wires run? Something's gotta set wrong or wired wrong if your friends sub worked fine
SidhuSaaB
May 30, 2020 12:40 AM
knight rider
Mar 4, 2016 08:59 AM
Houston
Oct 8, 2015 01:27 AM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
