Subs miss fire
Old Apr 23, 2004 | 11:56 AM
Zepmac's Avatar
From: South Boston home of the 2003 National Hockey Champions Tier II Midget "A"
Subs miss fire
my subs do this now and i have no idea why, the first timeit happened i took it back to the installer and he switched amps and said it was a bad amp but it happened again and now they dont even work again i have no idea how to fix this or what causes this so if anyoen could give me a lil info on whats upwith my situation lemme know
Old Apr 23, 2004 | 02:30 PM
Jonesi's Avatar
Can you give us some more details.. You say it was misfiring and now assuming a couple days later it just stopped working..?
First things first...
CHECK YOUR GROUNDS
Check all your connections
Check your fuses
Then get back to us..
Old Apr 23, 2004 | 02:45 PM
Slooo97CL's Avatar
CHECK YOUR GROUNDS
Check your fuses
check the polarity too
Old Apr 24, 2004 | 11:27 AM
Hobo's Avatar
Flap.
^^ good advice
Old Apr 24, 2004 | 10:58 PM
1-cl-2-go's Avatar
A-CL Auto-Tech
from what you described, it seems that it could be a couple of possible problems: the negative cable is either the same size as the 12v cable or smaller(it should always be thicker than the 12v cable), the ground cable is mounted too far from the amp(the ground cable should be grounded within 6" from the amp), the subwoofer coil is overheating due to a non-stable load from the amp(i don't think that this would be your situation because kicker doesn't use liquid cooled voice coils and kicker can handle 2-ohm loads very well.
Old Apr 24, 2004 | 11:50 PM
Hobo's Avatar
Flap.
well if he was using 0 awg power cable.. i would be tough for him to use a size bigger for the ground :P
most likely the ground point is not clean or the bolt is loose.
Old Apr 25, 2004 | 10:25 AM
Slooo97CL's Avatar
the ground should be 3 feet or less, i dont think size of the wire really makes a difference. I mean of course you should not use 18 gauge wire for a ground. but that is just common sense. just need to make sure the ground is secure/and the metal is exposed and not painted over. from what the problem sounds like, really doesnt sound like a ground. bad ground = no workie work, or play/stop/play/stop
you are right maybe the way the amp is bridged it's handling an OHM load that is "clipping" the amp, always possible.
Old Apr 25, 2004 | 05:05 PM
1-cl-2-go's Avatar
A-CL Auto-Tech
that's when bare strand or braid wire comes into effect. there's always something bigger!
Old Apr 25, 2004 | 06:04 PM
Hobo's Avatar
Flap.
^ you slut bun
Old Apr 26, 2004 | 11:07 AM
1-cl-2-go's Avatar
A-CL Auto-Tech
^ you slut bun
:0 why bash? it's all good, i'm just spreading a rule that i learned in my 12-volt electronics class and found to be correct. perfect example: look at your battery terminal which cable is fatter? + or - ?
Old Apr 26, 2004 | 12:11 PM
Vector02's Avatar
Your groud should always be the same size as your power wire.
Old Apr 26, 2004 | 06:20 PM
Hobo's Avatar
Flap.
Re: ^ you slut bun
im just joking :P
and right now my battery terminals have so many wires it confuses me !
2x 4ga from alt
1x Stock wires
1x 0 awg power wire for the system
2x 4ga grounds
1x stock ground
1x 4ga that goes off to the grounding system i made
Old May 1, 2004 | 07:37 PM
Hobo's Avatar
Flap.
Zepmac, you ever fix this problem?
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
