Subs miss fire
Location: South Boston home of the 2003 National Hockey Champions Tier II Midget "A"
Subs miss fire
my subs do this now and i have no idea why, the first timeit happened i took it back to the installer and he switched amps and said it was a bad amp but it happened again and now they dont even work again i have no idea how to fix this or what causes this so if anyoen could give me a lil info on whats upwith my situation lemme know
Can you give us some more details.. You say it was misfiring and now assuming a couple days later it just stopped working..?
First things first...
CHECK YOUR GROUNDS
Check all your connections
Check your fuses
Then get back to us..
CHECK YOUR GROUNDS
Check your fuses
CHECK YOUR GROUNDS
Check your fuses
CHECK YOUR GROUNDS
Check your fuses
A-CL Auto-Tech
from what you described, it seems that it could be a couple of possible problems: the negative cable is either the same size as the 12v cable or smaller(it should always be thicker than the 12v cable), the ground cable is mounted too far from the amp(the ground cable should be grounded within 6" from the amp), the subwoofer coil is overheating due to a non-stable load from the amp(i don't think that this would be your situation because kicker doesn't use liquid cooled voice coils and kicker can handle 2-ohm loads very well.
Flap.
well if he was using 0 awg power cable.. i would be tough for him to use a size bigger for the ground :P
most likely the ground point is not clean or the bolt is loose.
you are right maybe the way the amp is bridged it's handling an OHM load that is "clipping" the amp, always possible.
A-CL Auto-Tech
that's when bare strand or braid wire comes into effect. there's always something bigger!
A-CL Auto-Tech
^ you slut bun
:0 why bash? it's all good, i'm just spreading a rule that i learned in my 12-volt electronics class and found to be correct. perfect example: look at your battery terminal which cable is fatter? + or - ?
Flap.
Re: ^ you slut bun
and right now my battery terminals have so many wires it confuses me !
2x 4ga from alt
1x Stock wires
1x 0 awg power wire for the system
2x 4ga grounds
1x stock ground
1x 4ga that goes off to the grounding system i made
InFaMouSLink
10-30-2015 09:43 AM
kb1rl
09-30-2015 10:17 AM
