sub location
Old Mar 23, 2004 | 10:34 AM
Redline's Avatar
sub location
Ive got a 12" Polk MOMO sub that im going to be building a new sealed enclosure for once i finally get my ride...for all of those audiophiles out there, what is the best direction for the sub to fire? It only needs like .88cuft of space, so I was wanting to put it in on one of the sides of the trunk so its out of the way and i can get to the spare if need be, but I dont know if this would be bad for imaging. Any ideas or suggestions would be cool...thanks.
Old Mar 23, 2004 | 12:10 PM
gfxdave99's Avatar
6MT Snob
my best results have always been with bandpass firing back, and sealed firing forward..
Old Mar 23, 2004 | 05:42 PM
Gpump's Avatar
You want me to break it?
you can build a 12" deep box that will fire into your back seat and still have access to the spare tire - my setup ain't the prettiest around, but it sounds good to me. Take out the 6x9 when you put in the sub, it will greatly increase the spl of your sub.
Old Mar 23, 2004 | 08:26 PM
ortiz's Avatar
Don't listen to me.
If you are using a high powered amp place it behind the seat facing towards the back.
Yes, you will get a better sound by removing the 6x9s, but you will get more road noise. So if you consistantly like it kinda loud take them out. If you listen at low volumes leave them in.
Old Mar 23, 2004 | 08:30 PM
tuan209's Avatar
its all preference. move em around and see which you like best.
Old Mar 24, 2004 | 09:10 AM
Redline's Avatar
so if i build it and have it firing towards the rear seat, how much space should i leave between the seat and the sub?, or does it matter...
Old Mar 24, 2004 | 09:30 PM
ortiz's Avatar
Don't listen to me.
technically all you would need is enough clearence to let the speaker vibrerate.
Old Mar 24, 2004 | 09:55 PM
Altersys's Avatar
Every car is different. Try it out with a test enclosure first.
-Alt
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
