Sub enclosure
Old Dec 15, 2000 | 05:33 AM
Guest
Guest
Posts: n/a
Question Sub enclosure
Question. I have 2 JL Audio subs that I use to have in my old truck. Standard enclosure. Installed the amp and ran the subs in the TL. But I feel that no matter what I do I can't get that nice tight bass into the cabin but get way to much of the ring bass. I tried taking out the stock sub, turning the box all different ways, but still did not feel a major difference. I am thinking maybe someone can give me a better idea on a enclosure design better suited for trunk applications. I have always had trucks and hadn't had to deal with this problem before.
I do not really listen to much bass music so I am just looking for a nice tight bass sound from my subs. If anyone has any suggestions it would be greatly appreciated. Thanks in advance.
Old Dec 15, 2000 | 09:04 AM
preludeshfan's Avatar
Post
hey dude what model of subs are they? i have a subwoofer program on my PC. it is the same program JL audio uses to speck their sub boxes. just give me the info and i can compare any boxes you want using the same subs. then you can decide what box you want.
email me and ill take care of the design for you.
formerly 98 prelude type SH
Currently 2001 Acura 3.2 TL With Navigation Black/Ebony
Old Dec 15, 2000 | 09:24 AM
ZodiakTL's Avatar
Acura TL-S
Post
actually i had the same problem when i transferred my system from my maxima to the tl... i have a ported box... i just switched to a sealed box and the base is great... tight and hitting.. no more of that dirty noise... what kinda box do u have?
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Custom Cross-Drilled Front Rotors / Alpine CDA-7863 Head Unit / Alpine G320 EQ / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by
Alpine MRV-1002 amp / Dual 10" JL Audio W-3 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers
Pics of my TL
Old Dec 20, 2000 | 10:31 PM
MToker's Avatar
Post
I have some dirty noise and I have two sealed JL12W6s. Wanna compute that with your bass program prelude?
2000 Laguana Green / NAVI, Burlwood Shifter, 35% Mirror Tint all over,2 x JL12W6s, Pioneer Premier P920R, MB Quarts Coaxial, PPI 2600.2 and 4400.2 , Pioneer 620 6Disc
My Acura
Old Dec 22, 2000 | 12:14 AM
Post
If you put each sub in 1 cubic foot you will have a roll off of 44.16 Hz i wouldent go any smaller than that or it won't sound to good. persinally i would go with 2 JL 10W6's and use .5-.75 cubic feet per sub that will give you a lot more tight bass. your problem is that in the truck you were a lot closer to the subs and you couldent get very low bass in the truck. now that you have a bigger car you are getting the ringing bass notes that the truck couldent produce. so i would go with smaller subs. what you want is smaller lighter weight cones that can move more quickly. they will also have a higher resonant frequency.
iesu3423
Oct 6, 2015 06:54 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
USACiCL
May 15, 2004 09:07 PM
guji2
Oct 13, 2001 11:47 PM
