TL: stock headunit wont accept code
Old Dec 11, 2012 | 12:04 PM
MIKE8898's Avatar
Bonki Ehrite!
Hello. I have a 2003 TL and the headunit is asking for the code. I am the cars first owner so I have the correct radio code and it has worked before. However it says error when I enter it. A buddy of mine knew to hold down the 1 and 6 button simultaneously and the radio gave two codes
U3007
L2803
Anyone know what these codes mean and what I need to do? Any help is appreciated.
Old Jan 28, 2013 | 09:19 PM
Powashiftin's Avatar
Find an underground garage where there is no radio signal. Punch in code and voila
Old Jan 29, 2013 | 09:45 AM
TLS1016's Avatar
7th Gear
Those codes you have can be used to retrieve the radio 5 digit code from a dealer or Acura direct. I just too had the problem where my radio would not accept the code even thought it was correct. What i had to do was disconnect the radio antenna which is located at the top of rear windshield under a plastic cover. I disconnected that and tried the code and it accepted and then i reconnected the antenna.
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
