TL: stock headunit wont accept code
Hello. I have a 2003 TL and the headunit is asking for the code. I am the cars first owner so I have the correct radio code and it has worked before. However it says error when I enter it. A buddy of mine knew to hold down the 1 and 6 button simultaneously and the radio gave two codes
U3007
L2803
Anyone know what these codes mean and what I need to do? Any help is appreciated.
U3007
L2803
Those codes you have can be used to retrieve the radio 5 digit code from a dealer or Acura direct. I just too had the problem where my radio would not accept the code even thought it was correct. What i had to do was disconnect the radio antenna which is located at the top of rear windshield under a plastic cover. I disconnected that and tried the code and it accepted and then i reconnected the antenna.
mada51589
05-03-2022 08:54 PM
Soul_Deamon
11-13-2018 04:44 PM
handsom-hustla
11-13-2015 05:04 PM
