CL: stock bose amp on 01 cl
Old Feb 16, 2011 | 04:23 PM
camjones92's Avatar
7th Gear
I need to know the location of the bose amp on a 01 acura cl i just installed 4 rockford frostgate prime series speakers now i need to know where the amp is so i can replace it with a 4 channel rockford frostgate amp
Old Feb 16, 2011 | 04:37 PM
camjones92's Avatar
7th Gear
i had to take the back seat out to put in the rear 6x9s and doing that i saw the wires it ether in the truck somewhere or in the rear panel on the passenger side but i was straped for time and could not investigate anyone other know?
Old Feb 16, 2011 | 08:36 PM
Kasper's Avatar
Registered Newbie
It's inside the rear passenger wheel well area. A little bit of a pain to get to. Gotta remove the trim around the trunk latch, then the molded carpet piece where your jack is. From what I remember, you'll only see a few bolts and the wiring harness because the amp is mounted from behind. Loosen the bolts, and the amp pops free.
Old Feb 17, 2011 | 03:32 PM
neyeswhip's Avatar
tigerstyle
You DO NOT need to take out the rear seat to swap out the speakers.
Old Jul 6, 2011 | 09:14 PM
CLkid187's Avatar
[quote=neyeswhip;12718172]You DO NOT need to take out the rear seat to swap out the speakers.[/quote
wats the easiest way to remove and replace the rear speakers? i was wondering if there was.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
