TL: Adding 4 chl amp to factory system
Old Nov 30, 2010 | 12:40 PM
Bones45's Avatar
Long GuyIsland
2003 TL, stock system
I have a 4 chl amp which I want to hookup. keep all existing components.
Will this be possible? will I be able to keep the stock sub working ( but not hooked up to the amp?
Old Nov 30, 2010 | 02:52 PM
fourthmeal's Avatar
If you aren't replacing the deck, then no it will work still (assuming you are tapping the wiring instead of outright removing it.
The sub works on its own amp (in the back), signal is given to it via the pre-amp wires in the harness.
Old Dec 22, 2010 | 04:47 PM
sickrex's Avatar
there should be a way this could be done, someone i know is running an aftermarket speaker amp with the stock navi head unit in his 3G TL, don't know how he had it done, but it is done
Old Jan 13, 2011 | 05:33 AM
demetri's Avatar
I am also very interested in adding an JL audio 4 channel amp and component speakers. I would rather leave the factory radio in place. Can this be done with good sound output? Do I need to use a sound processor the JL audio cleansweep unit? Is the amp behind the rear seat only powering the factory sub?
Also want to plug in a parrot blue tooth kit and adding an amp will save me from purchasing a specific wiring harness. any advice?
thanks
Old Feb 11, 2011 | 04:12 PM
Holliewood's Avatar
9th Gear
yea i want to know how do you run an amp after market amp with the factory hu? 99 tl with navi:-)
Old Feb 11, 2011 | 04:38 PM
pinoyromeo16's Avatar
8th Gear
I would suggest replacing the head unit and speakers. The bose speakers are at best, 'ok', but it leave a lot to be desired. The car is very well insulated as is, but you may also think about dynamats.
Old Feb 11, 2011 | 07:25 PM
Holliewood's Avatar
9th Gear
ok i would replace the speakers cause i dont get the sound i want from them, but i want to keep in the factory hu cause of the factory navi. i want it to talk thru my speaker.
Old Jul 6, 2011 | 09:26 PM
CLkid187's Avatar
Holliewood you could go to your local car audio spot and get an adapter to hook up to your factory speakers that you can just jump the RCA's up to your amp from it. if you plan on changing out your speakers your still gonna be in the same situation, i believe the only way around it would be to change out the hu. from reading on here otha members are sayin you can keep the factory navi and swap out the hu and keep the voice dont quote me on which type of hu tho you would have to look into it
tpraka300
3G MDX (2014-2020)
57
Dec 10, 2018 02:17 AM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
scionxb3003
Oct 2, 2015 05:50 PM
Sep 15, 2015 06:44 PM
Pegon95
Sep 15, 2015 01:54 PM
