CL: stock bose amp on 01 cl
I need to know the location of the bose amp on a 01 acura cl i just installed 4 rockford frostgate prime series speakers now i need to know where the amp is so i can replace it with a 4 channel rockford frostgate amp
i had to take the back seat out to put in the rear 6x9s and doing that i saw the wires it ether in the truck somewhere or in the rear panel on the passenger side but i was straped for time and could not investigate anyone other know?
It's inside the rear passenger wheel well area. A little bit of a pain to get to. Gotta remove the trim around the trunk latch, then the molded carpet piece where your jack is. From what I remember, you'll only see a few bolts and the wiring harness because the amp is mounted from behind. Loosen the bolts, and the amp pops free.
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
