SteveStMS - Pls help with Video-NAV kit
I'm working on the kit and I've complete soldering the RGB1.
I'm now trying to connect my 4PDT relay. But when I look behind the NAV, I see 4 plugs,
a 1-pin, an 8-pin, a 12-pin, and a 16-pin plugs. and on each of them, there are 1 wire, 8 wires, 7 wires and 9 wires connected to them respectively.
I can't seem to locate the 20-pin which you've describe.
How do you know which is Pin-1, Pin-2 & Pin-10 (power connection for the RGB1 to the NAV)?
and finally, which are the 4 wires for the video signal to the NAV, would the 4 wire (green, white, red, black) be from the same plug? cuz every one of them have a green wire... AHHH!!!!
THANKS!!!
Dude, here you go
Personally, I would use the Navi connectors found in the trunk area instead of the one's behind the Navi in the dash. Really, you need the scematics (found in Helms manual) before you start cutting.
THANK YOU!!!
SteveStMS, Kensteele, you two are the man!
another question from the clueless guy... how or where can I draw power to the decoder from the NAV_DVD player, in another words how can I hook up the orange(constant, black(accessory), blue(ground, can I ground it elsewhere, ie, on the circuit board?)
My decoder is powered from wires from the fuse box, completely separate from the Navi. It is also grounded from a separate wire that connects to a screw someplace in the chassis that's well grounded.
Just wanna celebrate my 'turning to a freak' post here!
Kensteele, so...the blue wire is labeled as 'remote' what exactly is it for? there are two connection to the wire, so I guess I should connect the main one right? thanks.
Power can be picked up from the 1st 8-pin connector. Pin 1 (upper left corner) is constant power for AVC-RGB1 decoder yellow wire. Pin 2 is the accesory power for AVC-RGB1 decoder blue wire and Pin 4 is ground for AVC-RGB1.
the RGB1 costed me $150...
+ ~$20 of wires and switch...
Steve, Ken, could you guys check and see if I've the stuff soldered properly...I posted it on the video to navi thread on top.
also...could you tell me which color wire runs -'ve current? the blue one on the RGB box is +'ve.
thanks. E
thanks. E
Hey YEE
I got the TL Electrical diagram book...Email me if you want copies of the NAVI wiring set
Tom
zyylo@aol.com
Tom
zyylo@aol.com
MrHeeltoe
20
02-23-2023 02:54 PM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
