stereo issues
Old Mar 3, 2009 | 03:41 PM
chrisr414's Avatar
stereo issues
so i unhooked my battery because i have a bunch of stuff stuck on it so i decided to clear it out. but my stereo keeps on saying error and i have no idea how to reset it. got any ideas?
Old Mar 3, 2009 | 04:17 PM
gold2003tl (90)'s Avatar
2003 TL-p
cd's are stuck? error er1 or somthing cus if that is then you need to replace that with an aftermarket
Old Mar 3, 2009 | 04:23 PM
JM604's Avatar
I believe you have to input your car's radio code after reconnecting your battery. It's a specific number for your car, so if you can't find your number, try the dealership or whoever you bought it from.
My number was on a little white card (credit card size), and I think it was 5 digits.
Old Mar 3, 2009 | 04:24 PM
juanclopez2786's Avatar
if your entering the radio code and it says error try disconnecting the antenna wire from the radio then entering the code and reconnecting antenna wire. it happened to my car when i first bought it and i found those instructions on this forum.
Old Mar 3, 2009 | 04:48 PM
chrisr414's Avatar
well i figured it out how to get the code im getting it from the shop i take my car into so hopefully that should do it cause it gives me five chances until i have to disconnect the battery again but this time ill have the code
Old Mar 3, 2009 | 05:34 PM
JM604's Avatar
IIRC, step-by-step instructions should be your car's manual.
Old Mar 3, 2009 | 07:11 PM
rattmann316's Avatar
if you pull up the d.side woodgrain you can "easily" access the antenna. if you pull up the p.side woodgrain you can "easily" access the radios serial number so they can get you a code if needed.
Old May 17, 2009 | 12:20 AM
tiguy99's Avatar
How hard is it to pull up the wood grain pieces?
snorf
Nov 4, 2019 06:44 AM
Kamakanani0
ILX Audio, Bluetooth, Electronics & Navigation
Nov 4, 2015 05:44 PM
ivegotthenav
Sep 11, 2015 07:51 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
