steering wheel controls
Old 05-18-2004 | 05:49 PM
I just had a Alpine 7998 installed the other day and i'm really starting to miss the steering wheel controls. Is there an adapter that will allow use of the steering wheel controls?
Old 05-18-2004 | 07:37 PM
StanMan's Avatar
PAC makes an interface and reportedly, can be directly connected to some alpines for a more reliable connection than using IR.
http://www.pac-audio.com/products/swi.htm
Old 05-18-2004 | 09:48 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
i've been thinking about getting a new headunits lately.. and i too want my steering wheel controls..
a remote control probably came with your headunit.. what you could do is find out where the wires from the steering controls are, then disassemble your remote controler and solder each wire of the steering wheels control to the corresponding button on your remote..and hide the controler somewhere under the dash.. i guess that would work..
anybody has the wiring diagram for the steering wheel controls??
@cUr@-TL
Old 05-18-2004 | 09:55 PM
shawhite's Avatar
the only draw back to those pac adapters is the fact that they are slow as hell.. you press the button and then have to wait a couple seconds for the unit to respond.. kind of annoying to me...
Old 05-19-2004 | 12:21 AM
Are there any other than pac that will work with our TL's?
Old 05-19-2004 | 10:52 AM
StanMan's Avatar
are you using the IR option or is it directly wired into the alpine?
Old 05-19-2004 | 10:54 AM
StanMan's Avatar
@cUr@-TL
not sure about this, but i think the radio uses/senses resistance to change options. anyhone know for sure?
Old 05-19-2004 | 01:19 PM
Laffinitup's Avatar
i installed a pac swix in my vehicle and it works perfect. placement of that unit is imperative. i have mine located in the upper left corner of my shifter. it works flawlessy.
Old 05-19-2004 | 04:27 PM
Good to here, I was starting to get a little skeptical for a while there.
Old 06-01-2004 | 05:58 AM
ynot82's Avatar
i install a PAC for my tl.s and it work great.
rockyboy
08-04-2024 11:35 AM
02-25-2020 10:57 AM
PortlandRL
09-14-2015 01:01 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 01:26 PM
MyKids&Cars
09-02-2015 01:03 AM
