Solution for whoever has problem with factory remote turn on wire
Sony XA-39MK2 Automatic Signal Switching Relay with Remote Turn on wires (Good luck with any search engine - I found nothing when type in this model name)
I just order one and will let you know how it work out.... My video sound sounds so crappy with the FM Modulator.
My problem is that:
As Most of you already know that the factory remote turn on wire has very low current. The problem is that when you splice to this wire and connect to your amps, the factory bose amp shut down. You could run an inline relay but low current relay is also hard to find. I have already try a few low current (less than normal 30A) relay and the bose still shut down. What I found is the Sony XA-39MK2 Auto Source switching relay with 2 input and 1 output and 2 TURN ON REMOTE WIRES, ONE PER INPUT. This unit will turn on your amps as you have input to either input channels.
This is also great if you have an add on MP3 player (Which I plan to get soon Neo35) No crappy FM Modulator needed. Probably great for the the Navi kit as well.
My problem is that:
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
