TL: SINGLE DIN problem
Old Jun 4, 2010 | 02:51 PM
kingstonn's Avatar
SINGLE DIN problem
I am using a kenwood deck. Or more specifically a Kenwood MP345U, which is a single din. The problem is that when installing the single din, it doesnt fit right. There is a gap about an inch or so long. What may be the problem. I am guessing it is with the dash kit, but these are the only dash kits offered for my Acura 2000 3.2 TL. There is a gap between the stereo and the cigarette lighter.
When i see what the other people have done, they seem to have double din, as you all realize the factory stereo system is much bigger than the single din. Please help.
Old Jun 4, 2010 | 07:34 PM
'03TL-S's Avatar
Get a single din dash kit and it should work fine. Did you get a double din dash kit and install a single din in there?
Old Jun 4, 2010 | 09:19 PM
kingstonn's Avatar
Yes it was a single din dashkit, and it is somehow not fitting.
Old Jun 6, 2010 | 05:58 PM
kriz2fer's Avatar
Didnt you already post this? You need to post pics or this thread is worthless! Did you buy the metra kit? It should fit the same as the double din kit with out the one inch pocket, or maybe your not installing it right?
Old Jun 6, 2010 | 10:45 PM
kingstonn's Avatar
where can i get the metra kit
Old Jun 7, 2010 | 12:00 PM
'03TL-S's Avatar
Look in the Black Market and check with our vendors. THey should carry single and double din dash kits. ~$20
Old Jun 7, 2010 | 07:33 PM
dykyy's Avatar
You should not have this problem if you are using the correct dash kit, chances are that you got the wrong kit. And a picture is worth a thousand words (hint, hint).
Old Jun 7, 2010 | 08:33 PM
Blazin Si's Avatar
Some of the kits are made for multiple vehicles, so you'll sometimes need to snap pieces off for the deck to fit your particular car. I had trouble with mine not too long ago. The directions weren't very clear at all.
Old Jun 8, 2010 | 09:20 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
you may just have to trim down the tabs on the dash kit for it to work right
Old Jun 10, 2010 | 03:30 PM
kingstonn's Avatar
problem fixed. :P used a metra kit and added cd holder.
Old Jun 11, 2010 | 11:10 PM
FR3SH_TL01's Avatar
6th Gear
THE PART NUMBER FOR METRA KITS ARE 95-7868B FOR DOUBLE-DIN AND THE SINGLE DIN IS 99-7868 IF YOU DO ORDER THE KIT JUST MAKE SURE YOU READ INSTRUCTIONS METRA IS NEVER WRONG AND ALSO REMEMBER YOU NEED TO ADD THE CD CASE ABOVE THE STOCK RADIO INTO THE AFTERMARKET KIT CANT POST PIKS CUZ IAM NEW TO THE WEBSITE HOPE I HELPED WITH THIS POST
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
urbtsx
Sep 27, 2015 09:40 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
