SHOCK SENSOR ? which wire to tap?
Old Oct 13, 2001 | 10:31 AM
LarryB's Avatar
ok there are more than a few yellow with silver dot wires down there. Can anyone give me better instructions on which wire to tap the signal onto.
Old Oct 13, 2001 | 11:17 AM
soopa's Avatar
The Creator
http://public.fotki.com/novawhitetyp.../dsc01600.html
dunno if that helps... hopefully NOVA will chime in... Joe?
Old Oct 13, 2001 | 03:37 PM
SilverKnight's Avatar
Retired. Not available.
Or check out this link. I hope it's clear enough.
EDIT: DUH .. forgot to post the link
http://www.acura-cl.com/forums/showt...nsor+installed
Old Oct 14, 2001 | 12:15 AM
LarryB's Avatar
Thanks guys. I installed 2 senors one under the dash and one in the trunk. My car had been vadailized by some punks at my high school twice in the past 2 weeks so I really appreciate your help.
Would any of you know of a motion sensor to make a beep but not set off the alarm that i could add to the stock setup?
If not is there an aftermarket alarm in which I could keep my OEM FOB?
Thanks again
Old Oct 15, 2001 | 02:36 PM
icy CL's Avatar
Thanks again
so did you have to remove the fuse box just like what silver did? i'm kinda hesitant to remove all that stuff.
Old Oct 15, 2001 | 03:49 PM
LarryB's Avatar
nah.. no need to remove anything
Old Oct 15, 2001 | 03:58 PM
Remove the screws to pull loose the fuse box makes it easier to get to the wire. You can just fine leaving the screws alone. I took out the fuse box to y'all the harness. Good luck.
soupi
14
Nov 15, 2015 11:15 AM
StevieB1503
ILX
Oct 8, 2015 04:52 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
thegipper
Sep 28, 2015 01:01 PM
