setting gains, please help!
Old Aug 28, 2006 | 02:31 PM
socal01cls's Avatar
7th Gear
before i get flamed, i do know about the two procedures using a voltmeter and adjusting the gain, or to crank it up till i hear distortion.
The thing is, when i use the volt meter, i most i could read is 4 volts at the highest gain for my sub amp, and 25 mV for my speakers. which is completely off from this web site
http://www.subwoofertools.com/forum/setgain.asp
also, when i cranked it up, i never heard any distortion that i can tell. yea, i am using a 80HZ and 1KHZ test tones.
this is my current config.
Eclipse CD343
2 jl 12 W3v3
PPI D1000/1 500watts x 1 channel
PPI PC4800 100 watts x 4 channel
the sub amp is cranked to max without distortion, and the speakers is cranked about 3/4 of the way.
Is this because my headunit has a 5V preout? i know eclipse makes pretty good head units, is that y? also, when i was setting up gains for my subs, i had my non-fader output set at 0. But how much could i crank it up? (ranges 0-16)? i have it at 10 right now and it sounds great. just dont want to push it too hard.
also, what should i set the QBASS to on the PPI amp?
there are soo many variables and i dont know how to exactly set it to get the maximum output with out blowing my subs.
Any help would be great! thanks in advance
gatrhumpy
19
Dec 31, 2015 04:22 PM
RobbDizzle
Oct 15, 2015 11:16 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
dirleton
Sep 25, 2015 12:25 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
