Running Wires
Old Jan 18, 2003 | 01:57 PM
IDQCL's Avatar
4th Gear
Running Wires
I have a 03 3.2 CL and i was wondering if anyone had a picture of how they tapped the RCA's into the Bose amp and where the bose amp is located and what needs to be done to access it, and also does anyone have a picture of where they ran the power wire thru the firewall. I have ran wires in cars before but I have not ever tried in my car before.
Thanks,
John
Old Jan 18, 2003 | 03:12 PM
Six Shifter's Avatar
an adult perspective
Check SilverKnight's thread in the A/V and Electronics's forum. He has pics of how he used his Bose amp to feed an aftermarket amp f/u/w his sub, location, what has to be taken out to get to it etc. The power wire comes into the interior above and to the right (I believe) of the gas pedal.
Old Jan 19, 2003 | 05:43 AM
jwong77's Avatar
Midnight Marauder
Hey I think I found the accessory to bypass that wonderful bose amp and install our own aftermarket one without cutting into the factory wires. It's called "oem-1", heres a link I found. www.tune-town.com/Cars/stuff/pac_oem1.htm
Old Jan 19, 2003 | 08:09 AM
shawhite_RENAMED's Avatar
if the cl is like the tl then the bose does not have a seperate amp per say.... actually the amp is in the stock eq.... the signal is sent out of the headunit thru the eq then back to the headunit to get amplified... so just tap into the sig before it hits the stock eq and put some rca connectors on it and there you go....
Old Jan 19, 2003 | 08:42 AM
The configuration for the CL and TL are NOT the same ... there is no EQ in the CL unless you install an aftermarket unit. All the Bose acoustical wizardry takes place in the amp, which is located in the trunk.
Old Jan 19, 2003 | 04:21 PM
well in that case just tap into the signal before it reaches the bose amp...
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
VA2000TL
Oct 2, 2015 08:26 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
