run a ps2 while the engine isn't running
Old Oct 14, 2004 | 07:42 PM
palidanx's Avatar
honk not beep
technical question out there for all you engineering type people:
if i want to run a ps2 while the engine is off, i believe i run the risk of draining my battery. I know capacitors act as a buffer for sound amps, but is it possible to install an inverter after the capacitor into a ps2? The only reason I ask is like if i want to play ps2 in front of a store that i'm waiting to open (haha just some random scenario) and i don't want to run my engine i wonder if putting it after the cap will be okay.. cuz i think the cap starts beeping when its low in power?
Old Oct 14, 2004 | 08:32 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I wouldn't recommend running the power off of a cap. Get an OPTIMA yellow top deep cycle battery. I heard these things can run for hours and hours before it's drained. They go for like $100-$150 I think.
Old Oct 14, 2004 | 09:17 PM
elduderino's Avatar
VP Electricity
Get the 1/2 Honda-size Optima - easy to hide...
Old Oct 14, 2004 | 09:41 PM
phirenze's Avatar
The extra b is for byobb
A capacitor will act as brief power source for the speaker amp in case a voltage drop from the main battery occurs (a/c turning on, etc..). I don't think you want to run a PS2 off of one.
Old Oct 14, 2004 | 11:39 PM
musicbox's Avatar
2004 TSX
Optima..
Old Oct 15, 2004 | 12:07 AM
palidanx's Avatar
honk not beep
what's the 1/2 size optima? Run a second battery?
Old Oct 15, 2004 | 09:47 AM
musicbox's Avatar
2004 TSX
I don't think you want a second battery, unless you're saying you're going to this every day for an hour or more without starting the car.
Old Oct 15, 2004 | 10:00 AM
elduderino's Avatar
VP Electricity
If you can fit the Honda-size small-form-factor Optima as a main battery, you're probably OK... you could run a second battery, but they are *a pain in the a$$* and rarely worth it.
There is no right way to do something stupid.
John Durbin, Autosound Category Manager, Directed Electronics
mada51589
Jan 9, 2025 04:40 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
01CLOwner
Oct 9, 2015 01:07 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
