Rockford Amps?
Old Dec 21, 2003 | 02:18 AM
brado's Avatar
new wheels = old school
Rockford Amps?
does anyone have any input on the rockford Power series amps. i did not know if they were quality, or just all quantity. i am looking at the 501bd Power series amp to power my 10 inch xtant sub that is in a slot ported box. thanks for any reviews or suggestions.
Old Dec 21, 2003 | 09:28 AM
Hobo's Avatar
Flap.
i dont have much experience with them, but a friend of mine had a one of there larger amps about a year ago, it had some bad overheating problems... but dont let this turn you away from them entirely, hopefully some one else will chime in.
Old Dec 21, 2003 | 07:16 PM
proaudio22's Avatar
-S namyaC-
Power series is still good stuff. Punch series is Best Buy shit now.
The overheating problem above was probably due to improper mounting.
Old Dec 23, 2003 | 04:30 PM
Hobo's Avatar
Flap.
well it was mounted in the correct direction (ie, not upside down) and with pleanty of space around it, eventually a few computer fans were added when the problem was noticed, it was prolly just a lemon..
Old Dec 24, 2003 | 07:55 AM
phipark's Avatar
Not Asian
I think you will be satisfied with the Power series. I have a Rockford amp and no overheating problems at all.
Old Dec 25, 2003 | 12:23 AM
Ron Burgundy's Avatar
Just the facts...
That would be great if your not looking to be a bass nazi...or gonna add any more subs later, If I remember correctly I don't think that the amps are regulated which means that the output will vary with the imout most of the time when your traveling your at 14.4 volts, but say ur at a stop light and got it craking a little your really draw on the battery (and caps too if you got them) bringing the 14.4 voltage of the car way down... the output of the amp will vary or could even shut off if your idling for long enough and it could surge might blow the fuses in the power cables...
Old Dec 26, 2003 | 11:09 AM
rmh3093's Avatar
Pass the dutchie!
Rockford power series sucks, Rockfor Punch series is awsome. The overheating problem was probably due to how the speakers were wired. Lots of people think if they bridge their amp they will get more power from the amp and that is miss leading. If you bridge an amp to get more RMS the peak power of the amp does not change. Also if an amp says it provides 100Wx2 @ 4ohm or 250x1 @ 4 ohm and u bridge the amp to get 250x1 and you hook 2, ohm subs to it in parallel the amp sees 1 2ohm sub. Less resistance means more power flow. So now your amp is putting out its peak power all the time and it overheats. Rockfords though will turn off so u dont burn up the transistors.
Old Dec 26, 2003 | 02:01 PM
brado's Avatar
i think you got it mixed up rmh...power is the better line of amps. i'm not gonna argue over the internet cause thats just gay, but all of us here know which is better. have a merry christmas man.
Old Dec 28, 2003 | 05:35 PM
Bluesman's Avatar
Sign: Slippery When Wet
I just added a 150S amp and a RFZ3408 10" sub in a sealed closure. I wasn't looking to entertain the hood just enhance the Bose and its all good sofar. Did it for $220 at Ultimate. I'm happy.
Old Dec 28, 2003 | 05:36 PM
Hobo's Avatar
Flap.
thats a good price for ultimate, someone ordered 0/1 gage wire for me and it was almost that expensive eek.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
