TL: Review my setup!
Review my setup!
Ok so here is what i plan on getting, please leave your comments/suggestion - Thanks!
2 of these - http://www.sonicelectronix.com/item_...24-10C124.html
Box - http://www.halfpricecaraudio.com/Dua...osure-Gray.htm
Amp - http://www.hifisoundconnection.com/S...id/0/SFV/30046
Capacitor - http://www.ebay.com/itm/VOODOO-Car-A...item3a79b45718
With a 4 gauge wiring kit... Thoughts?
That looks good for a Really Entry Level System....
Box Might sound "boomy" but with Those subs its a given anyway.
The AMP is Fine for those Subs.
Im not Fan of Capacitors (Better do a Big3)
4 Gauge Amp Kit will do..
Boomy is when you Get Bass like a "Pump, Pump" and Only that but nothing close to Flex your Rear Window or Shake your Trunk XD = (DEEP BASS).
I Agree try to get a Single Mid-Range Sub +150 Bucks! Plus a Good Single Ported Box and youll be Set (You will get the Boom! But with some Deep Bass here and there).
Don't get a cap or kicker comps or build your own box
Use http://www.reaudio.com/box.php to design a box based on the required specs of the subs you purchase use 3/4" MDF
I'd suggest getting
Amp- http://www.sonicelectronix.com/item_...RZ1200.1D.html
Subs- two of http://www.sonicelectronix.com/item_...-07CVR122.html
Use rockfordfosgate wiring wizard to make sure you run the amp/subs at 2 ohms
The system i just listed is is about the same price and more than double the power here is a good wiring kit for it to
ok: http://www.sonicelectronix.com/item_...ik-AKIT-4.html
Good : http://www.sonicelectronix.com/item_...er-SK4641.html
I'd suggest getting
caps are bad.. if your using more power then your alternator can produce constantly then your eventually going to drain the cap and now your alternator is trying to power the car/system and fill your cap... the cap is good for loud bursts here and there but no good for consistent bass which is often listened to
joflewbyu2
08-18-2019 10:38 PM
ITSJESTER
17
12-06-2018 02:29 AM
