TL: Review my setup!
Old Nov 7, 2012 | 07:21 PM
Mineme's Avatar
Acura
Arrow Review my setup!
Ok so here is what i plan on getting, please leave your comments/suggestion - Thanks!
2 of these - http://www.sonicelectronix.com/item_...24-10C124.html
Box - http://www.halfpricecaraudio.com/Dua...osure-Gray.htm
Amp - http://www.hifisoundconnection.com/S...id/0/SFV/30046
Capacitor - http://www.ebay.com/itm/VOODOO-Car-A...item3a79b45718
With a 4 gauge wiring kit... Thoughts?
Old Nov 8, 2012 | 12:08 AM
Skirmich's Avatar
That looks good for a Really Entry Level System....
Box Might sound "boomy" but with Those subs its a given anyway.
The AMP is Fine for those Subs.
Im not Fan of Capacitors (Better do a Big3)
4 Gauge Amp Kit will do..
Old Nov 8, 2012 | 02:10 PM
Mineme's Avatar
Acura
What do you mean by boomy? And how noticeable will it be?
Old Nov 8, 2012 | 08:46 PM
Mr. Hutch's Avatar
Imo you should get one better quality sub rather then 2 lower quality subs. Just my .02
Old Nov 9, 2012 | 02:29 AM
Skirmich's Avatar
Boomy is when you Get Bass like a "Pump, Pump" and Only that but nothing close to Flex your Rear Window or Shake your Trunk XD = (DEEP BASS).
I Agree try to get a Single Mid-Range Sub +150 Bucks! Plus a Good Single Ported Box and youll be Set (You will get the Boom! But with some Deep Bass here and there).
Old Nov 11, 2012 | 01:54 PM
NickFury's Avatar
I dont think youre gonna need a cap. you are only runing 300 watts with that amp.
Old Nov 30, 2012 | 08:52 PM
viperrgh2's Avatar
8th Gear
Don't get a cap or kicker comps or build your own box
Use http://www.reaudio.com/box.php to design a box based on the required specs of the subs you purchase use 3/4" MDF
I'd suggest getting
Amp- http://www.sonicelectronix.com/item_...RZ1200.1D.html
Subs- two of http://www.sonicelectronix.com/item_...-07CVR122.html
Use rockfordfosgate wiring wizard to make sure you run the amp/subs at 2 ohms
The system i just listed is is about the same price and more than double the power here is a good wiring kit for it to
ok: http://www.sonicelectronix.com/item_...ik-AKIT-4.html
Good : http://www.sonicelectronix.com/item_...er-SK4641.html
Old Nov 30, 2012 | 08:53 PM
viperrgh2's Avatar
8th Gear
caps are bad.. if your using more power then your alternator can produce constantly then your eventually going to drain the cap and now your alternator is trying to power the car/system and fill your cap... the cap is good for loud bursts here and there but no good for consistent bass which is often listened to
joflewbyu2
Aug 18, 2019 10:38 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
saturno_v
Sep 27, 2015 08:13 AM
dirleton
Sep 25, 2015 12:25 AM
