Replacing sub/amp in Bose system....
Old Dec 15, 2006 | 02:33 PM
J32a2FTW!'s Avatar
BoostedSiOwner
Easy swap?
The factory radio does a nice job of filling in the lows, I want a little more than that. My OWN amp and MY choice of sub. Is this possible and relatively easy?
Thanks!
Old Dec 16, 2006 | 11:34 AM
TLBaller's Avatar
sure its easy, if you've done it before. If not, i would suggest having a someone with experience do it for you.
Your idea of "swap" will cost you more than you think b/c you'd have to change out your speaker wires, rca wires, etc. and that requires running wiries from your car battery all the way to your trunk (usually requires going under the carpet of your car). so its not just an EASY SWAP.
Old Dec 16, 2006 | 01:25 PM
J32a2FTW!'s Avatar
BoostedSiOwner
Well, Ive installed PLENTY of systems before.
Why cant I use the stock wiring? What is the gauge on the power lead? I only want ~ 2-300W rms amp. I have no problems rigging the mounting for the sub. So the gauge doesnt need to be beefy at all. Im thinking even 10-12G should be fine w/those numbers.
Old Dec 16, 2006 | 01:44 PM
SpeedyV6's Avatar
I thought elduderino said that all you need to do is splice in some RCA connectors.
https://acurazine.com/forums/showpos...80&postcount=6
Old Dec 16, 2006 | 03:40 PM
J32a2FTW!'s Avatar
BoostedSiOwner
That would be hot.
Anyone now know what gauge the Amp's power lead is?
Old Dec 16, 2006 | 10:27 PM
fuzzy02CLS's Avatar
14 or 12 gauge. It doesn't look any bigger then that.
Old Dec 16, 2006 | 10:31 PM
J32a2FTW!'s Avatar
BoostedSiOwner
I should be able to run a little amp/sub combo off that.. Nothing more than 300w.
Old Dec 17, 2006 | 11:17 AM
J32a2FTW!'s Avatar
BoostedSiOwner
Here is a link off this site that should help me... anyone.
I didnt have time to search when I posted it.
https://acurazine.com/forums/audio-video-electronics-navigation-22/%2A%2Aaudio-video-diy-info-faq-all-models-%2A%2A-299065/
Old Dec 17, 2006 | 04:16 PM
seanberry's Avatar
Use this wiring diagram to help you...
http://seanberry.com/acura/04tsx_audiosystem.jpg
This is what I did to make it easier
http://seanberry.com/acura/rca_conversion.jpg
I bought a used stock amp for $20 on ebay and used the connection piece.
Old Dec 17, 2006 | 04:19 PM
J32a2FTW!'s Avatar
BoostedSiOwner
So is the amp thats in back not only for the sub? Im confused.
Old Dec 18, 2006 | 07:27 AM
fuzzy02CLS's Avatar
Did you read the FAQ at the top?
https://acurazine.com/forums/showthread.php?t=299065
Old Dec 18, 2006 | 06:03 PM
J32a2FTW!'s Avatar
BoostedSiOwner
Mostly.
The diagrams I have seen appear to ME that there is the HU amp fo rhte 4 speakers, and a seperate amp, that sits in the rear for the sub.
Im sorry I just dont have time to search through the abundance of information on this site. If I missed it, can you please tell me.
Thanks in advance!
Old Dec 20, 2006 | 06:51 PM
J32a2FTW!'s Avatar
BoostedSiOwner
Anyone?
Old Dec 21, 2006 | 07:32 AM
fuzzy02CLS's Avatar
What car do you have?
Old Dec 21, 2006 | 05:46 PM
J32a2FTW!'s Avatar
BoostedSiOwner
03 TL Type S w/Navi + Bose system.
Old Dec 22, 2006 | 07:31 AM
fuzzy02CLS's Avatar
The TL I don't know about. On the CL all you do is follow the FAQ instructions. The CL doesn't have a factory sub, so all I did was splice in a LOC to the rear speakers.
Old Dec 22, 2006 | 09:05 PM
J32a2FTW!'s Avatar
BoostedSiOwner
Thanks for your help. Looks like I will have to crawl in the trunk and find out.
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
Billu99tl
Sep 13, 2015 11:30 AM
