Replace Front Speaker Wires
Old Apr 1, 2005 | 06:33 PM
rokji's Avatar
rokji
Question Replace Front Speaker Wires
On my gosh~!
After reading very helpful tips from this forum I finally
decide to replace my speaker wires. (I got 4x90W RMS for my component speakers)
Back doors were ok but front doors are so so hard...
Anyone knows device can help run wire through rubber boot on front doors?
Old Apr 1, 2005 | 06:37 PM
rokji's Avatar
rokji
oh it's 2002 TL S
Old Apr 1, 2005 | 06:41 PM
DRM600's Avatar
just pop the ends out of the holes. that makes it easy to manipulate the boot, the wire loom in it and the new speaker wire. you'll find that it's much easier when you can straighten out the boot to eliminate the right angles. it's easy to pop them back in if you just work one section at a time.
Old Apr 1, 2005 | 08:25 PM
DerrickM's Avatar
I found it very difficult and ended up just poking two holes in each boot. The rubber gripped around the wire for a good seal, but I put urathane adhesive on it just to be safe. Not the cleanest... but it's very difficult to work in the hinge area because your hands barely fit in there.
Old Apr 1, 2005 | 11:06 PM
DRM600's Avatar
just unbolt the the limit bar.
Old Apr 24, 2005 | 12:00 PM
dnd2984's Avatar
whats the limit bar?
Old Apr 24, 2005 | 10:27 PM
optomos's Avatar
I=X - optomos
Its a bar that limits the door from being opened to far. If you open the door and look between the hinges you will see a bar. There is only one.
Old Apr 25, 2005 | 06:59 AM
StreetEffectz's Avatar
A wire hanger and liquid soap will do the trick - you'd be AMAZED how easy the soap makes it. Pull the wire hanger through the boot, tape your wire to it, apply a little soap, and pull - VIOLA!
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
08 NBP TL
Sep 8, 2015 08:49 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
