Removing front seats
Old Apr 3, 2005 | 12:25 PM
Cubanmix's Avatar
Is there a DIY on removing the front seats, looked and didnt find anything. If someone can knows, please post.
Old Apr 3, 2005 | 12:27 PM
elduderino's Avatar
VP Electricity
Of what?
Old Apr 3, 2005 | 12:37 PM
StreetEffectz's Avatar
Which car? For the most part, they are all just 4 bolts that go into the floor pan. Remove them and the seat is loose. IF you are taking them OUT of the car, disconnect the battery and then remove the connectors under the seat - if you do it with the battery connected, you will trip the airbag lights. When you reinstall them, plug the connectors back in, and then reconnect the battery.
Old Apr 3, 2005 | 01:07 PM
elduderino's Avatar
VP Electricity
With the TSX, I pulled the pass seat with the battery connected, but I NEVER turned on the Ignition without the seat plugged in. It was a PITA to put it back in every time I wanted to check something with the key on : )
Old Apr 3, 2005 | 05:03 PM
Never took a TSX seat completely out yet - good to know I don't have to disconnect the battery though
Old Apr 3, 2005 | 07:05 PM
elduderino's Avatar
VP Electricity
With the 2005's, there's not much point - not putting anything under that power passenger seat. (Drat...)
Old Apr 5, 2005 | 12:27 PM
Cubanmix's Avatar
Thanks guys, well I was looking to wire the the seats for some monitors in the headrests and wanted to take the seats out so I could use some care. Do you guys usually wire the seats while theyre in or do you take them out. Also I have an 02 tl sorry for not specifying. Oh and thanks eldude I got the visors to work.
Old Apr 5, 2005 | 01:16 PM
elduderino's Avatar
VP Electricity
Most HR video installs are done with the seat in the car. But if I were doing a car for the first time, I'd probably take the seat out of the car and put it on a workbench.Then when I ran the wires inside a car, I'd have an idea of what the heck I was doing : ) (no, I havne't done that part before, just watched>..)
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
08 NBP TL
Sep 8, 2015 08:49 PM
truonghthe
Sep 7, 2015 11:17 PM
